Lime1GT
- Nov 12, 2016
- Winnipeg, Mb. Ca.
- Thomas
- 2017 Mustang GT PP
First why a 160 thermostat? The pcm relies on all inputs from sensors including coolant temp. OEM thermostat is best.
Do you have an aftermarket tune running? If so are the fans turned Off by the programming or the temperature they turn On is extremely high?
According to spedy7's diagram the two motors use one ground G100 that also has connectors C1074 and C144 in the circuit. Did you check the circuit and the connectors?
