Strange noise at idle
Alocoroco
Houston
Alocoroco
2016 mustang gt
Hi all. Got a 15 mustang gt that's making a strange sound at idle. Once the clutch is pressed in it stops but comes back when it is released. Any ideas?
Shifting_Gears
South Florida
2016 Mustang GT
I’m having the exact same issue. Took it to a dealer and they “couldn’t replicate it”… LOL.
That being said, I am fairly certain it’s the slave cylinder (aka throwout bearing).
Are you having any issues shifting?
Transmission has to come out to fix it. The part is about $150, labor is what makes it so expensive if you don’t do it yourself.
Also a good time to replace your clutch (depending on milage) while it’s apart.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
Slave cylinder is definitely not the same thing as a throw out bearing. Check the throw out bearing, may want to replace the rest of the clutch while you are in there.
velocity550
Virginia
Joshua
2020 Mustang GT
A friend of a friend was having this same exact issue on his 2019 gt with the MT-82, it turned out to be the throw out bearing. He replaced it himself in his garage and also put a Mcleod clutch in.
Andrew@Lethal
West Palm Beach Florida
Andrew
2003 10th Anniversary Cobra / 2003 Ford Lightning
Alocoroco
Houston
Alocoroco
2016 mustang gt
Ahhhh mann. It only has 55k miles. Clutch feels solid
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
Technically they're not the same thing, of course. But as far as I know in the Mustang they're integrated into one unit and can't be replaced independently of one another.
Shifting_Gears
South Florida
2016 Mustang GT
Or we could call it a hydraulic throwout bearing. That’s why I related the two, since both are terms used often on here.
Shifting_Gears
South Florida
2016 Mustang GT
Mike Pfeifer
Wesley Chapel, FL
Didn’t realize they were integrated together as one unit. How do you bleed that thing?
Stephen@lethal
2020 Mustang Gt500
Shifting_Gears
South Florida
2016 Mustang GT
The original Ford part is “self bleeding” and as Vlad said requires some fancy footwork to eventually bleed the air from the line and build pressure.
Exedy states theirs can be bench bled to jumpstart the process. A few other manufacturers make them, but I’m not sure if they’re able to be bench bled.
Shifting_Gears
South Florida
2016 Mustang GT
Interesting. This is what I’m used to working on.
Yeah, pretty standard. That’s how the T-45 looks in my old GT.
The MT-82 slave/TOB is fixed in place by two bolts and rides on the input shaft. There’s no release arm/lever since it’s actuated hydraulically.
