dragonacc
I have mentioned a couple of times about alternatives to the fueling problem but the way other DI platforms are getting around their problem are throttle body injection or port injection setups. Although the setup is more complicated than the stock fuel system it does allow for better idle and low rpm driving along with an easy ability to change out to larger injectors if needed.
That is a possible solution. I'm willing to try an auxiliary fuel system if that's what turns out the best, but if you add meth/water into the mix as well now you have 3 fuel systems you are trying to keep in harmony.
Ideal for me would be a HPFP and injector upgrade + meth to help give safety/octane boost and clean the valves a bit.
