Oh no! Rod Knock?
Fix or swap if you had limited funds
  • Total voters
CalvinClick
Calvin
2015 Mustang EcoBoost
If you had to guess, would you say this is engine knock? Any advice is welcome, thank you.
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
Hard to nail down from a video but I think you can reasonably rule out rod knock, that sounds very different.
Dadillac
Iselin NJ
Don
2018 Ecoboost Premium manual
Rod knock is usually a deeper sound. That sounds like one of the pulleys on the accessory drive
Don
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
Not lower end, top end use a stethoscope to find where it's coming from
ktp1598
Mount Washington, Ky
Bobby
2019 Kona Blue California Special
Did you ever figure out what the noise was?
Jaymar
Portland, OR
Jaymar
The low side fuel pressure sender? Out of curiosity, what led you to that conclusion?
CalvinClick
Calvin
I am doing this before anything else, since its been purposed as a way to prevent eco boom.. Last thing I want to do is make the problem worse, but I am only hopeful that this new sensor will help. I am also going to remove my exhaust & intake to see if it could be a moving particle stuck inside. The pipes including the cat have been damaged due to bottoming out. If that doesn’t show any signs, I will move on to the turbo. The video fails to show that there is low end noise just as much as the top end. I would like to take a look at my timing chain, but I need to find it first lol. Just a broke new dad trying to keep his pony alive, so to replace the engine would take about 5 years of savings.. By then, I would hope electric swaps become an affordable thing, since I now deliver after losing my job (have a cargo trailer with big cooler and backseat delete) Easy to remove aftermarket seats as well.. I miss her just talking about it =(
Oh, and per the advice in this thread; I will be using my scope to look into the top end.. however, being inexperienced at internals, I probably will have to post those pictures to have more expertise help. Thankfully the scope has that function and look forward to getting those back to y’all. Thank god for the mustang community that is here.. everybody’s input has been encouraging through this hard time.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Sounds like your engine identifies as a diesel now lol. But I agree with the above.
D K
Denver
Popemobile
Did this ever get resolved?
It almost sounds like it had someting to do with cam/followers
