Steeda S550 Mustang Rear IRS Subframe Support Brace (2015 Coupe) - Now Available
Discussion in 'Steeda Autosports' started by [email protected], Mar 20, 2015.
  1. David@Steeda
    [email protected] Well-Known Member
    First Name:
    David
    Vehicle(s):
    Bolt-on, slammed S197
    Oct 17, 2014
    United States
    3,433
    1,907
    Rating:
    100%
    3   0   0
    With the release of the new S550 Mustang, Steeda knew that addressing the IRS system would be a top priority. Being the first production Mustang with an IRS since the 03/04 Cobra’s, we knew there would be a great opportunity to capitalize on Ford’s new piece by giving it the Steeda advantage. As with any suspension system, deflection is an issue if it’s present. Anytime a piece is moving, twisting or vibrating when it should be stationary is a major problem. One of the areas team Steeda wanted to focus on was the rear IRS subframe.
    As you have seen with our IRS Subframe Bushing Support System, it limits the movement of the subframe by filling in the voids of the OE bushings. With Steeda’s IRS Subframe Support Brace, we have taken the S550 rear suspension to another level!
    Built in-house from 4130 chrome moly steel and powdercoated silver metal flake, this part isn’t only strong - it also looks great under your new Mustang! What we did was tie together 3 very important points on the S550 chassis. We utilized existing threaded holes in the rocker panel (the strongest part of the body) and connected that to the front mounting location of the IRS subframe and the rear mount of the lower control arm and toe link. Connecting these 3 points together not only adds rigidity that was lacking in the rear, but also more control of the whole car.
    Also, unlike competitors kits that have not been released yet and only replace the factory bracket, our Steeda kit supports that bracket while connecting to 2 additional locations, therefore providing twice the support! Best part about this kit is it uses all existing holes in the chassis so the car doesn’t have to be modified in any way and adds no NVH whatsoever. :)
    Product Photos: steeda-s550-mustang-rear-irs-subframe-brace-2015-coupe-555-5754-0.jpg steeda-s550-mustang-rear-irs-subframe-brace-2015-coupe-555-5754-1.jpg steeda-s550-mustang-rear-irs-subframe-brace-2015-coupe-555-5754-2.jpg steeda-s550-mustang-rear-irs-subframe-brace-2015-coupe-555-5754-5.jpg steeda-s550-mustang-rear-irs-subframe-brace-2015-coupe-555-5754-6-7.jpg
    [email protected] likes this.
  2. Todd15Fastback
    Todd15Fastback Well-Known Member
    First Name:
    Todd
    Vehicle(s):
    2015 Mustang GT PP Fastback
    Dec 10, 2013
    Atlanta, GA
    10,530
    3,838
    Rating:
    100%
    1   0   0
    Very, very nice. This looks to be a really easy installation process?
  3. OP
    David@Steeda
    First Name:
    David
    Vehicle(s):
    Oct 17, 2014
    United States
    3,433
    1,907
    Rating:
    100%
    3   0   0
    It was actually pretty easy! We will be posting an installation video for the DIY group!
  4. Mikeg4572
    Mikeg4572 Well-Known Member
    First Name:
    Vehicle(s):
    2015 Magnetic GTPP
    Dec 9, 2014
    Scottsdale, Arizona
    633
    148
    Rating:
    100%
    1   0   0
    Will this help with wheel hop also?
  5. OP
    David@Steeda
    First Name:
    David
    Vehicle(s):
    Oct 17, 2014
    United States
    3,433
    1,907
    Rating:
    100%
    3   0   0
    Sure will!
  6. Mikeg4572
    First Name:
    Vehicle(s):
    2015 Magnetic GTPP
    Dec 9, 2014
    Scottsdale, Arizona
    633
    148
    Rating:
    100%
    1   0   0
    I think I will have to do the bushing supports and this brace. Nice job Steeda! Went to track last night and wheel hop was bad.
  7. FB_Magnetic_GT_PP
    FB_Magnetic_GT_PP Active Member
    First Name:
    Flint
    Vehicle(s):
    '15 GTPP
    Sep 14, 2014
    Crescent City, FL
    Ordered! Thanks, David!
  8. 2wheels4me
    2wheels4me Well-Known Member
    First Name:
    Vehicle(s):
    GTPP, Much-Modded Fiat 500 Sport, 911 Carrera S
    May 20, 2014
    SoCal
    508
    113
    0   0   0
    David, what is the combined weight of the two bars plus bolts, please? Any clearance issues possible or is it tucked away? This looks like it might be yet another good thing to do.
  9. Autocratic
    Autocratic Well-Known Member
    Vehicle(s):
    2015 Mustang GT
    Mar 17, 2015
    Dallas, Tx
    53
    Just to clarify this kit comes with two braces for a left and right side installation?
  10. BOSS 32V
    BOSS 32V Well-Known Member
    Vehicle(s):
    15 GT pp
    Nov 1, 2014
    Bay Area, CA
    234
    74
    0   0   0
    Another to do on the list!
  11. OP
    David@Steeda
    First Name:
    David
    Vehicle(s):
    Oct 17, 2014
    United States
    3,433
    1,907
    Rating:
    100%
    3   0   0
    Right, it's a pair!
  12. gsxr1300
    gsxr1300 Well-Known Member
    First Name:
    Jason
    Vehicle(s):
    2015 Mustang GT PP
    Nov 16, 2014
    MA
    2,098
    452
    Rating:
    100%
    2   0   0
    With these and the support, inserts, bushings installed, can the sub frame still be possibly mis-aligned?
    2wheels4me likes this.
  13. OP
    David@Steeda
    First Name:
    David
    Vehicle(s):
    Oct 17, 2014
    United States
    3,433
    1,907
    Rating:
    100%
    3   0   0
    This has nothing to do with subframe alignment, so if yours was mis-aligned from the factory then the only way to fix it is by picking up our IRS subframe alignment kit: http://www.steeda.com/steeda-s550-mustang-irs-subframe-alignment-kit-2015-all-555-4438/
    I'd recommend the subframe alignment kit paired with our inserts - if yours was off-center then your car will need to be aligned post-install. Then I'd recommend our vertical links and these Steeda IRS support braces.
  14. gzstang
    gzstang Who's stang? It's gzstang
    Vehicle(s):
    2015 Mustang GT w/performance pack
    Sep 7, 2014
    Lincoln Nebraska
    395
    97
    Garage Profiles:
    My Steeda build list keeps growing....have no choice...it's time to apply for Steeda financing LOL
  15. gsxr1300
    First Name:
    Jason
    Vehicle(s):
    2015 Mustang GT PP
    Nov 16, 2014
    MA
    2,098
    452
    Rating:
    100%
    2   0   0
    Next time I'll just buy a Steeda vehicle.
    [email protected] and H1 GT like this.
Loading...
Share This Page
