Steeda Front Parking Camera
23GreenGremlin
Mechanicsburg, PA
2023 Mustang Mach 1, P0389, Eruption Green, "Gremlin"
Just installed my Steeda front parking camera on Sunday Steeda 50-1015-100 Mustang Front Parking Camera Kit (15-23). It mounts to the center of the front bumper with tape or screws and interfaces with the SYNC 2, 3, and 3.4 system. Provides a clear front guide to help prevent bashing curbs and destroying your front spoiler. It is pricy but less than the cost of one new spoiler.
Not hard to install, except for the contortionist position necessary to route the wiring under the dash. I found both the Steeda install video Protect Your Front Splitter With The Steeda Front Parking Camera Kit (youtube.com), and the video sent in by another customer Steeda Front Camera Install 2015 to 2017 Mustang with Sync 2 (youtube.com), to be very helpful. Key steps are to watch the videos a couple of times, prepare the camera harness on the bench, lower your windows, jack up the front of the car, disconnect the battery neg terminal, drop the front underbelly pan, remove the air filter box, and remove the dash trim and SYNC screen. Took me about 3 hours going slowly.
When prepping the harness, the Steeda video skips over two key bits. There is a short jumper harness that needs to be removed and put back in the box because it is not required. The second is that there is a connector on the end of the black and red wire that has to be cut off and the resulting leads soldered to the main harness where you find the corresponding black and red wire (see photos).
Tips I would add are to properly solder the connection to the camera harness instead of using crimp connectors as shown in the Steeda video. Tape up the harness so it doesn’t get caught on everything behind the dash. Route the wiring from the back of the SYNC through the console, across the driver side foot well, then out through the firewall to the camera. Steeda shows it going the other way and requires you to shove the whole harness up from the back of the console to the back of the SYNC. Much easier to just feed the single camera lead down instead. You will end up with a good handful of excess wire that I ended up wrapping and securing with a zip tie just below the air box. This is where you will need to disconnect the wiring if you ever have to remove the front bumper. I marked my wire with a big red tape flag so it would be obvious in the future. To get the camera to come on you have to hold the OK button on your steering wheel. Depending on what you have showing on your dash be careful that you don't accidentally reset your trip. I keep my display to extra gauges so no issue. Finally, I did figure out that I needed to disable my rear camera delay setting. That tended to cause the rear camera to hang up at times for longer than expected.
From the video, when I pull up to the shelves on my workbench, the forward edge of the red is about 18” from the shelves. The next cross line on the red indicates about 12” from the shelves. If you have an HP or PP2 extended front spoiler, then the cross line would be closer to 6” from an object.
23GreenGremlin
23GreenGremlin
Mechanicsburg, PA
I want to do this but it seems like such a pain to install )=
No worse than an oil change under the car. Pulling the dash apart went easy. A lot of my time was just being fussy and getting everything just so. Now, getting my big head and arms under the dash was not pretty. If I was smart I would have removed the seat to have room. Instead I ended up upside down on the driver's seat with my head under the dash and my arms feeling like I suddenly became a T-Rex.
Rob_R
Virginia
Robert
SPF Cobra, 26 Jeep Moab 392, 24 Power Wagon, 88 Jeep YJ
Nice write up, Steve. I ordered one of these 1 year ago and started the install on my Mach this past weekend. I ran into some hiccups that I haven't resolved. A quick question - Did you utilize the green "Aux Cam Trigger" wire on a +12V source?
I have not utilized the +12V source. When I press the OK button, nothing happens. The front cam will display when I put the trans in reverse. Once I hit the OK button, then the reverse cam image appears until I put the trans in neutral. I have contacted Steeda but I have not received a definitive answer from them yet.
23GreenGremlin
23GreenGremlin
Mechanicsburg, PA
Rob,
My guess would be one or more of the dip switches are not configured correctly. As much of a pain in the butt as it will no doubt be to pull the dash apart again if you have reassembled it, you should check and double check that your dip switches inside of the control box are set correctly and fully moved into place. The instruction page shows them pretty clearly, but it is easy to misconfigure or not get a switch all the way into position.
As it arrives in the box from Steeda the switches are configured for a car without a rear camera. If your car came from the factory with a rear camera you have to change several of the switches so that it reads the right camera based on the inputs.
Second, if you look at this photo, the orange, purple, and green wires that are shown disconnected were not used for my application and I just wrapped them up with the wiring harness. The red and yellow RCA connectors in the photo were connected and taped together and the black and red camera wires were soldered and shrink wrapped.
Hope you get it worked out. If you do, definitely make sure your rear camera delay (stays on longer) is turned off in your SYNC settings. I also figured out this morning that the front camera displays a reverse image (right is left and left is right). Not optimal when trying to park, and I will drop Steeda a note about that one.
Good luck, Steve
23GreenGremlin
23GreenGremlin
Mechanicsburg, PA
Here are the correct dip switch settings for cars with a factory backup camera.
Rob_R
Virginia
Robert
Rob,
Good luck, Steve
Thanks, Steve! I had tripled checked the dip switches on the board that I have it memorized! 10010011. I do not have my dash buttoned up yet or my air filter box back in until I get this sorted. Thank you for the clarification on your wiring. No 12V trigger. Based on your suggestions, I will make sure the dip switches are fully set in the desired position and I will make that change to the rear camera settings. I'll let you guys know how I make out with this.
Regarding the reverse image, you need to cut the white wire loop at the 4 pin connector that is on the camera cable.
23GreenGremlin
23GreenGremlin
Mechanicsburg, PA
Thanks for the tip on the camera wire! At least I won't have to tear the dash apart again. It is probably in the instructions and I just missed it. Again, hope you get yours worked out unless they just sent you a bad control unit.
Rob_R
Virginia
Robert
I read about the white wire on the Steeda web page. It is mentioned a few times in the Q&A section and the review section.
I do not believe Steeda will replace the control unit as I purchased the unit a year ago. Steeda started to say that when I called yesterday with questions, but I interrupted and said I just want some technical assistance with this. The Steeda answer was to provide an engineer's email that works for their supplier company that builds (and probably designs) the unit. The gentleman is out of the office until tomorrow. We will see if he replies to my questions.
Rob_R
Virginia
Robert
Just a follow-up to my note above. I moved each dip switch and ensured they were firmly seated in the correct position. The back up cam was already in the non-delay setting. I triple checked all of the connections.
I still have the same front cam behavior where if I press OK and after a few seconds I can hear a very faint click, I then release the OK button and there is no image. If I shift into reverse (manual trans), then the front cam activates. While still in reverse, briefly pressing the OK button will change the view to the rear cam. I cannot switch back and forth after that unless I start the sequence when not in reverse. I can turn off the front cam while in another gear or neutral by briefly pressing OK and again I hear the faint click. I do not believe I have anything wrong on my end. The camera is being triggered but not displaying when it should.
I have a spare cam I will plug in to see if that is the issue, but I doubt it is.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I’m probably going to have to add this to my car.
i just added a similar kit to my Tacoma and its pretty useful. When I was just driving the Mustang daily I got pretty accurate at parking it without hitting my giant splitter, but now that Im mostly in a truck and only sometimes in the mustang, I could use a little help.
The splitter:
23GreenGremlin
23GreenGremlin
Mechanicsburg, PA
The splitter:
Now that's a spoiler! You almost need a guy to ride around with you and get out when you are parking to guide you in with the two long orange lighted sticks they use at the airport.
Rob_R
Virginia
Robert
Hey Steve, did you happen to note the firmware version of your control box? There was a sticker on the bottom of mine. Version 3.1
23GreenGremlin
23GreenGremlin
Mechanicsburg, PA
Sorry I did not pay attention to it and now it is buried in the dash. I did check the box, and it does not list the firmware version.
