Steeda CAI and Lund tune
TN GT
Middle Tennessee
James
'19 GT Premium PP MT82
I just placed an order for the Steeda S550 Mustang ProFlow Closed Cold Air Intake and plan to order the nGauge and Lund Flex Fuel tune from Beefcake on Monday. Does anyone have any experience with this and know what I could expect in HP increase? I have a 19 GT.
Zelek
Hutto, TX
2021 Mustang Mach 1
You should check the other thread on this. I believe someone took off this intake because of the MAF turbulence it caused. Maybe your experience will be different but something to look at regardless.
Timeless
South Carolina
2024 Grand Highlander Hybrid Max Limited
^^^ As stated above another thread on here shows that straight 93 or E85 should be good but the flex does not like it.
tj@steeda
Timothy
AZ18yote
Arizona
Bryan
Correct. I actually just sold it to another member not planning on going flex. The maf turbulence was an issue for e learning to function correctly. If going straight e85r or 93 not an issue. I actually bet it'll be a beast on e85r. Unfortunately I am extremely dependent on the learning to work correctly since we don't have real e85 in AZ just the flex fuel blend. I will say while logging and testing on 91 (AZ also doesn't have 93) that the Steeda CAI did pull harder in the mid range than the stock intake.
beefcake
Bethel
2018 Ford Mustang
