squared vs staggered tires and wheels
Grintch
Hunstville
2015 GT PP
It has reported before that the PP rear wheel requires a spacer to work up front. Thanks to it's 52mm offset (vs 45 for the front PP wheel).
marjen
2015 Mustang Ecoboost
Ct
2015 mustang Ecoboost premium
I received the wheels. Going to try a test fit with the 9.5s up front hopefully this weekend.
marjen
Ct
Did a test fit on the front with the wheel today while getting an oil change. The 9.5s went on without issue.I guess I can't say 100% for sure as I did not have a tire mounted on the wheel, but everything seemed to fit. Nice aggressive look. The 9.5s have a +35 offset.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
As long as the wheel clears the calipers and the strut your good brotha.
gundam83
Sacramento, CA
2015 Mustang GT Oxford White
I'm going to be running a Forgestar F14 20x9.5 27mm squared setup. What size tires should I put on it? It'll possibly be dropped on Eibach Sportlines so I don't want any rubbing.
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
You can safely run 255/265/275 width tires on a 9.5" wide wheel. At least this is my answer:cheers:
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
You have a few options actually
255/35/20
265/35/20
275/35/20
drop it low you'll be fine this platform has some nice inner room for those sexy drops. :thumbsup:
Spot on brotha :headbang:
marjen
Ct
Well i dont think I ever posted pics after I got the wheels installed, so here are a couple. 19x8.5 and 19x9.5 with 35/255R19 and 35/275R19 Tires.
