Bluemustang
Hey all, I'm considering a change from my Ford Racing track springs because I feel like this car needs linear springs. The car corners extremely well but I don't think I like the feel of the progressive springs. On the highway at speeds 70-80 or above, the car doesn't "feel" as settled as I think it should be. I know the car can do it and go 100+ if I want it to as I've taken curves at 120 before no problem. But the steering feel over bumps at speed is inconsistent. It doesn't feel like I think it should. It discourages me from going fast because the car feels like it's going faster than it actually is. On less than perfect highways I'm getting passed by regular passenger cars and made to feel silly. The car has completely different feel when I'm on or off the throttle. Under heavy or medium throttle the car feels more or less locked down and as soon as I get off the throttle it feels unsettled. Lighter throttle at speed - the car feels vague.
It seems like the spring rate is constantly changing and I think this is what is giving the odd feeling I am describing. I think that this car really needs a linear spring and if I recall correctly - when I had BMR SP080s and Koni Sports it felt way more consistent in all areas. On/throttle, weight shifts, speed high or low. But I ended up going to the FRPP setup because I was unhappy with the harshness of the ride and what I believe was too much compression on the Koni shocks. I have a marginally better ride quality now but the inconsistency of the progressive springs can make it actually ride worse in some situations if that makes sense.
So I would like to seek opinions on what springs to pair with my Ford Racing shocks or other combinations with parts I already have.
I still have the BMR SP080s in my garage and the Konis. However my suspension has changed since I ran that combo. I have a bunch of other suspension bits such as:
BMR sway bars, BMR toe links, BMR vert links, BMR CB005,Steeda bumpsteer, Steeda RLCA bearing, Steeda black urethane diff inserts, Steeda billet shock mounts, FRPP toe bearing, MM CC plates, FRPP strut tower brace. I do not want to take these parts off as it took considerable time and expense installing them, which I did for valid performance reasons.
I'm not looking for a Cadillac ride. I have a track suspension setup and I realize it will be harsher than stock. But I want a more consistent handing experience and a more confident/stable FEELING at high speeds.
I've PMed with [MENTION=10281]BmacIL[/MENTION] and I think we've come up with a good compromise of:
BMR 089/082 with my existing FRPP shocks and run STOCK tie rods in place of the Steedabumpsteer kit. Our thoughts seem to be that this will minimize the geometry changes from the stock car and the linear spring rate of the BMRs should lend to a very consistent and planted feel. I think that is what I'll do because it uses parts I already have (sans the SP089s which I'll have to buy). But I wanted to seek other opinions in case any one else has a better idea. And hopefully I'll have a combination that will satisfy me for years.
1. BMR SP089/082 with FRPP shocks and stock tie rods
2. BMR SP080s with FRPP shocks and Steeda bumpsteer
3. Either BMR combo and Koni Sports w/ stock or Steeda tie rods depending on front drop
4. BMR Handling with FRPP shocks
5. BMR handling with Koni Sports
6. Another linear spring (you suggest) and FRPP shocks
7. Another linear spring and Koni Sports
GT350R is another good option is looks like. I'd like to minimize geometry changes hence the minimal drop front idea. And I don't want to lower the rear more than 0.5 inches.
Suspension gurus, what would you do if you were me? I'd like to get the best combo with minimal parts/installation cost. Any input from anyone is welcome.
And thank you to [MENTION=10281]BmacIL[/MENTION] - I appreciate your advice as always.
