SPRING RATES & DROPS: ALL IN ONE THREAD!!
terryz
SF, CA
2016 Mustang GT base manual
After so long, has anyone figured out the spring rate for Eibach pro-kit?
Several sources point out that they are not progressive. I had them with Koni yellow and think it's a little too stiff for DD. Knowing the spring rate would give me some idea about my ideal spring rate.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
200/800
What are your Koni settings? It's pretty easy to get a bad ride with the wrong damper settings, even with softer springs.
terryz
SF, CA
200/800
About 1 quarter from soft for both front and rear. I have also experienced with higher damping settings, but found softer rebound gives me slightly better ride. I am not sure if softer damping always give better ride.
BmacIL
Enginerd
Naperville, IL
Not always, no.
I'd try going up a bit in front, to like 3/4-1 turn. It should help keep the car flatter overall. No matter what you're going to have a "sporty" ride, but the control of the body changes how harsh it feels.
terryz
SF, CA
Not always, no.
Do you think lowering the car also has an adverse affect on the ride because of reduced suspension travel other than higher spring rate? I am actual considering switching back to stock height, with either my stock non-pp springs or a used set of pp springs.
BmacIL
Enginerd
Naperville, IL
Not unless the bumpstops are not adequately trimmed, or suspension bushings are not clocked. I know Eibach uses their bumpstops in their rates, but I would think you'd be better off trimming those too.
GuardEcoBeast
AR
Guard 16 Ecoboost
Whiteline EB and v6 lowering springs.
Front 170 in/lbs Rear 673 in/lbs
Lowers Front 35mm (1.3 in) Rear 30mm (1.1 in)
Whiteline GT
Front 202 in/lbs Rear 673 in/lbs
Lowers Front 35mm(1.3 in) Rear 30mm (1.1 in)
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Whiteline GT
In/lbs.
Man, those are some soft springs! :lol:
SVOBullitt
Charleston, SC
Chad
2018 GT PP1 301A A10, Steeda Stop The Hop, Minimum drop springs, Pro action shocks and struts, UPR Vertical Links, spherical bearings, Steeda Xpipe , VMP Odin 88 MM pulley, Lund Tuned
spring combo, SP089 with SP086
ALL BMR Springs are Linear Rate/Wound
BMR SP080 Performance Springs: 1/2" / .50" R
170lb/in Front
740lb/in Rear
BMR SP083 Handling Springs: 1.2" F / .50" R
300lb/in Front
980lb/in Rear
BMR SP086 Drag Springs: 1.2" F / .50" R
150lb/in Front
800lb/in Rear
BMR SP089 Minimal Drop Front Springs: .875" Drop
170lb/in
Will mixing SP089 with SP086 Work well? Where I live I am rubbing with my current springs Steeda Linear Ultra lights. I need more ground clearance and I plan on running 325/30r19 tires in the rear and 285/35r19 in the front on SVE gt350r repops 19x10 front 19x11 rear for street , and getting a drag setup. currently running full steeda stop the hop package.
BmacIL
Enginerd
Naperville, IL
Yes they work quite well, though being an EB the drag fronts will drop about 1" instead of 1.2". If you still want the minimum drop 089's, they'll lower the front around 0.7" for you. The Drag rears are SP088, fyi.
SVOBullitt
Charleston, SC
Chad
Steeda Ultra Light Linear definitely drop more than advertised , I needed to space mine up , tired of dragging everywhere.
BmacIL
Enginerd
Naperville, IL
Are you dragging at the very front or in the middle (like on speed bumps and such)?
SVOBullitt
Charleston, SC
Chad
speed bumps, high crown parking lot entrances, It seems like around here no one has lowered cars in mind.
SVOBullitt
Charleston, SC
Chad
Thanks I will be replacing them.
