CVCashmere
- Mar 28, 2017
- South Jersey
- Carl
- 15 GT Vert w/Steeda lower brace, PP sways & susp
Hello
My vert was imported from Canada.
The only visual difference is that the lower grill is not your typical pattern. Rather, it appears to be the same grill used if you buy the package with the front sensors on them.
The reason is simple...now you can get the Ford accessory cable to attach to the standard engine block heater and have the plug run out through the front of the grill.
I understand a few northern states also require a standard engine block heater and also have the same grill.
So...if you think you have either front sensors or an engine block heater-check your lower grill.
Thanks
CVCashmere
Thanks
CVCashmere
