I've heard of and experienced myself first hand, starters going bad.
From what I have experienced with the original starter for my 94 Cobra, when the car was shut off and key removed from ignition, the starter solenoid shorted and somehow jammed. When that happened the starter pinion remained engaged, making a horrible grinding sound against the flywheel... (no damages to flywheel teeth). The car was turned off, but the starter was shorted and getting power trying to spin, but the car didn't restart at all, because it didn't turn over the engine... The only way I could stop the grinding was to immediately disconnect the battery
That may be a possibility in your situation - but I would tend to think if it did do that, you surely would not be walking away because it makes a horrendous noise... you'd know immediately... LOL
If you car is restarting - better use ebrake assembly, leave it out of gear or disconnect the battery like others have suggested... otherwise you're going to have a much bigger issue than a mystery car restart...
