so I messed up
16s550
Bay area
2016 GT M6 performance pack, whipple charged
ordered a gt350 knob to swap onto my car. using Steeda tri ax. and of coarse it didn't twist on. didn't remember that my gt has different transmission than gt350 lol. my question, is there anyway to make this knob work? it looks like the threaded part has a Philips head at the end of it. wondering if that means I can swap out the threaded part that fits only transmission? hope so love the knob. has great weight to it..
H@mmer
NE Georgia
2017 GT w/ Too Many Mods
CJ Pony Parts has a knob they've already re-threaded.
I'm sure a local machine shop could do it for a minimal charge.
16s550
16s550
Bay area
ok sweet. can I do it with a tap and die set? if I take to a shop what size do I tell them to rethread it to? also thanks for the help! I was super pumped than ended up spending like 20min to get my old knob straight and reverse work again lol.
ronemca
ON Cda
Ron
2016 P/EB w PP
It is not possible to simply cut a different thread pattern into a hole that is already threaded; you would end up with a very loose & wobbly knob.
Dr. Norts
Ontario, Canada
2015 Race Red Mustang GT
Helicoil it.
16s550
16s550
Bay area
I would think increasing it to correct size would be a good fit. If anything use tephlon tape. Im sure they are both metric. Just one is probably a 12mm and other a 14mm. My guess.
Genxer
2015 Mustang GT / Perf pack / DIB
If you increase the tap size enough it will clean up. You can look up the tap drill diameter spec'd for the new threads and calculate how much it will clean the old threads off. Sometimes you can get away with a little truncation of threads but full engagement is stronger.
