https://www.corvetteforum.com/forums/c7-general-discussion/4027005-ticking-noise-from-motor.htmlMine definitely gets better when the car warms up. Would a DI pump do that?
Not banging the cylinder wall, the pin is held in the piston by two circlips. The noise is most likley the pin rattling in the small end bearing of the connecting rod. Seen it and heard it many times in the past.If a wrist pin is banging the cylinder wall that bad, you'ld have a seriuos oil burner in short time, or a busted piston.
I’ll check it out but I’ve got both the tick and the rattle. Both the rattle and what I believe is normal fuel injector noise is consistent. Same pace. Rattle is 2-3k rpm. Fuel injectors I hear at idle. The tick is inconsistently spaced. Almost like a hot exhaust settling while it cools. But obviously up towards the engine bay. Ceratec is on the way for the tick. Warm up the car to mitigate the rattle and know the fuel injector sound is normal.https://www.corvetteforum.com/forums/c7-general-discussion/4027005-ticking-noise-from-motor.html
ticks are common in cars with DI. Usually it's the DI fuel injectors but each case is different.
I don't know anything about the rattle. I don't have it. Ceratec didn't work for me.I’ll check it out but I’ve got both the tick and the rattle. Both the rattle and what I believe is normal fuel injector noise is consistent. Same pace. Rattle is 2-3k rpm. Fuel injectors I hear at idle. The tick is inconsistently spaced. Almost like a hot exhaust settling while it cools. But obviously up towards the engine bay. Ceratec is on the way for the tick. Warm up the car to mitigate the rattle and know the fuel injector sound is normal.
Strangely enough, my 2017 has a hint of the 2k rattle when the engine is cold. Once warmed up, it's quiet as a mouse. Doesn't burn a drop of oil and not concerned about it at all. Every Ford mod motor I have had has made noise.
My old 5.4 2v F150 had piston slap so bad it sounded like a diesel. Still running strong as I sold it to a buddy. Has almost 200k on it now.
My wife's old 4.63v in her explorer made some cam phaser noise I think. Got rid of it at 100k, noise never changed and the car ran perfectly. Never used any oil for the 12 years we had it.
My current 2011 5.0 F150 also has some piston slap on warm up. Pretty loud actually, almost like a rod knock. Once at full temp, no noise. I guess some reports of oblong cylinders...people were having short blocks replaced under warranty. Nope, not concerned and truck runs great.
Just turn up the radio people!
I don't expect it to work for the rattle. Too many examples of it working for the tick. Sorry it didn't work for you, but at worst, it's a 20 dollar experiment that fails. Juice is worth the squeeze.I don't know anything about the rattle. I don't have it. Ceratec didn't work for me.
