Smart key programming
Ttop86ta
Nh
Bob
Mustang
I have a 2019 Bullitt and am trying to program a third smart key. I've followed the procedure in the manual but haven't had any luck.
Has anyone successfully done this and have any tips? Key orientation, is there any indication that the process is underway at any point, anything really. I've tried it timing the process with a watch, going faster slower and nothing. I've done this before on a bunch of cars and never had an issue.
I have new batteries in all the key fobs and the my key menu indicates there is 3 keys programmed to the car. I only have two so the third key floating around is a separate issue, but it should be able to accommodate 4. The 3rd smart key is used, but bought from a retailer that claims to check them before reselling. Is there any way to independently verify it's functioning?
I am hoping to be able to do this without involving a locksmith or the dealer.
ORRadtech
Atlanta, Georgia
Some stores that sell keys have testers that can tell if a fob is transmitting. Batteries Plus comes to mind.
Without reading the Ford manual I found this. If it's different from what you have tried you might give it a shot. If it's the same then I'm zero help short of suggesting clearing all the keys and reinstalling the ones you have. Forscan may help or some of the more sophisticated scan tools could do it.
If it comes down to a dealer or a locksmith, I'd go with a locksmith every time.
https://www.programyourremote.com/c... a,intelligent access keys readily accessible.
Wingnutzz
Woodland Park, CO
David
2022 Mustang EB
I programmed a third fob for my 2022 with no problem since I had two programmed fobs. Worked first time following the instructions in my owners manual.. I purchased the third fob from Northcoast Keyless, as some owners had issues programming fobs purchased on Amazon.. Wanted one where people had no problems. It cost a few dollars more but I wanted to avoid issues. I had the physical key cut at a local locksmith.
whizkidder
Georgia
Ron
2017 GT Premium Convertible
I did a third key fob for my 2017 GT using Forscan. No issues. I did use a genuine Ford key, and not a cheap knockoff.
Ttop86ta
Nh
Bob
Mustang
Without reading the Ford manual I found this. If it's different from what you have tried you might give it a shot. If it's the e then I'm zero help short of suggesting clearing all the keys and reinstalling the ones you have. Forscan may help or some of the more sophisticated scan tools could do it.
https://www.programyourremote.com/classified/2019-ford-mustang-keyless-entry-remote-fob-smart-key-programming-instructions-listing-9668.aspx#:~:text=2019 Ford Mustang Keyless Entry Remote Fob Smart Key Programming Instructions,-Call 877-675&text=Note: You can program a,intelligent access keys readily accessible.
That's actually slightly different. Will try.
Ttop86ta
Nh
Bob
Mustang
My key appears to be a genuine Ford key, just not brand new.
gvn49
George
2020 Mustang, 2020 Explorer, 2007 FX4,1985 Mustang
2020 did two extras one a my key I keep in a emp bag hidden in the vehicle in case I'm out and one stops working, this worked for me.
Read and understand the entire procedure before you begin. This one works for 2020 Mustang
  1. Remove the rubber covering from the cupholder. Place the first programmed key in the backup slot at the bottom of the cupholder, then press the push button ignition switch.
  1. Wait five seconds and then press the push button ignition switch again.
  1. Remove the intelligent access key.
  1. Within 10 seconds, place a second programmed intelligent access key in the backup slot. Press the push button ignition switch.
  1. Place the unprogrammed intelligent access key in the backup slot and press the push button ignition switch.
Programming is now complete. Verify the remote control functions operate and your vehicle starts with the new intelligent access key.
If programming was not successful, wait 10 seconds and repeat Steps 1 through 7.
Australia
Adrian
2017 Ford Mustang GT
I have a 2017 GT and I need to program a second key, when I purchased my car, it only came with one key. I noticed there are difference types of Forscan programmers would you mind confirming the type of Forscan programmer you have. Can you also confirm if you can program a second key with the Forscan programmer?
whizkidder
Georgia
Ron
I used an OBDLink EX usb cable and a Windows 11 laptop. I believe Forscan requires you to have two currently programmed master FOBs, so I cannot confirm whether you can program a second FOB if you only have one.
MiamiGT350
S. Florida
You only need one master key with Forscan to add an additional key (third in memory). You can then follow up and wipe all keys, then add them both. This second step removes the lost 2nd key.
Note: if you wipe keys, the car will still remember the master key until you correctly add the first new one. No need to worry about messing up.
Australia
Adrian
Thanks for the reply
afgunn
North Carolina
Alan
Thanks! Great advice and help. Will be trying it this afternoon.
afgunn
North Carolina
Alan
OK... did this just two days ago and it was definitely easy with the Forscan program. It did take me several tries because the bluetooth OBDII interface would not work with Forscan to extent of programming the keys, so I had to order the recommended interface cable. Then I had to pay for the Extended License ($20) as the free Trial License would not allow me to program keys. But... I did get it done. Once I had everything it went quickly and smoothly!
Thanks again!
