Short block…. Compression ratio?
09jsw
East coast
2015 Guard PP GT
RPG doing mine in 12.1. I checked with tuner before hand and he said not a problem even on 93 he will just limit timing until I do E85.
I would never go lower then stock compression. This is a very high tech engine and not some old school Ford with shit flow design.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
At some point loss of timing advance negates any gain from compression.
12 to 1 on pump gas with a blower is asking for trouble. Unless a gen 3
09jsw
East coast
2015 Guard PP GT
I’ll be running E85 90% of the time until winter. I won’t be on pump unless it’s winter time. Guess I didn’t word it correctly.
K4fxd
NKY
SolarFlare
S. Fla
2015 CO GT
how is a gen 1 or 2 at 12:1 asking for trouble but a gen 3 ok?
K4fxd
NKY
SolarFlare
S. Fla
2015 CO GT
I don’t doubt it. Maybe cap timing 1 or 2 degrees lower. I’m talking about the basic setup of 8-10psi.
at the end of the day anyone buying a mustang to add a power adder then building a motor to run pump 93 is asking for trouble…..and slow time slips.
engineermike
La
2018 GTPP A10
So what’s your solution if you want to go fast on 93?
SolarFlare
S. Fla
2015 CO GT
I’m assuming you’re joking since cars have gone sub-8’s on pure pump gas. Seriously, though, for folks wanting a fast car that runs on common fuel, what would be your advice? Surely not a camaro or challenger…
link to coyotes running 8s with boost and Nothing but 93…
engineermike
La
2018 GTPP A10
I asked what your solution was if you want to go fast on 93. You said “you don’t”….except it has been done. I didn’t say coyote. So what’s your solution in a modern full-weight car?
Jackson1320
California
Jaxson
2015 mustang gt
The DI helps with detonation prevention.
The gen1 or gen2 can be just as safe as a gen3 with 12:1. It’s easier to have your tuner adjust the tune to safely run 93 with 12:1 then it is to change the compression ratio when you go e85
If you are planning to run 93 only then 12:1 on a gen1/2 is going to be more harm than good. But if are you planning on running e85 most of the time in then 12:1 is not a problem
