KingKona
Nope. That's why I mentioned that others who have done it would chime in about the necessary labor.That's more or less what I've been hearing. Have you replaced your shifter?
im gonna start with bushing and throw parts at it till something takesYeah, I was bummed to find that they don't make the full shifter for Ecoboost. I'm really curious how the Shifter + 2 post bracket is though. I'm sure at least (1) person on this forum has it haha
Copy that. Hopefully more people chime in.Nope. That's why I mentioned that others who have done it would chime in about the necessary labor.
Just find what you want and pay someone to install it.Copy that. Hopefully more people chime in.
I'm glad that setup is working for you! Do you ever get locked out of gears with the Ford Performance shifter or has the Steeda bracket fixed that?When I did mine it was pretty easy with regular wrenches... just a pain to get the stock shifter lockout off as your fighting the boot but then at that point recommend a aftermarket lockout and shift knob, mine uses bolts now instead of the plastic tabs but all depends on your tool selection you have, I do work at a shop that has a pit I can work under too so different then on Jack's so can be unnecessary added labor
so the notchness got worse with new bushing ?I have a Ford Performance Short Shifter with the steeda shifter bracket and Feels Super notchy, about an inch lower which is perfect height for the armrest and its amazing in how much shorter the throw is, I really recommend it and also I haven't done it yet but I'd recommend the whiteline trans bushing, besides that I don't experience any higher (nvh? I think that's what it's called- trans noise) then stock. I would recommend to switch to 3.55 for the ecoboost which will keep you in boost quicker as it'll wanna accelerate quicker through the revs which is my goal as I canyon carve my ecoboost!
EBs are low RPM torque monsters. RPMs are totally un-necessary. In fact, they don't seem to like them.....3.55 for the ecoboost which will keep you in boost quicker as it'll wanna accelerate quicker through the revs which is my goal as I canyon carve my ecoboost!
I have the Raceseng Slammer shift knob and love it. It was a pretty dramatic upgrade from the OEM shift knob imo. The Slammer is 1.4lbs but Raceseng has a ton of other options.Thank you! I appreciate it!
The shifter is a good suggestion! I've been eyeing a 350 gram shifter for a while now, so that could work out. Which shifter do you have?
And has the Motul improved the low temp operation for your shifter at all?
Wow. That's a beauty! 1.4lbs seems super heavy for a shift knob. Are you on the stock shifter?I have the Raceseng Slammer shift knob and love it. It was a pretty dramatic upgrade from the OEM shift knob imo. The Slammer is 1.4lbs but Raceseng has a ton of other options.
You can find them here:
https://raceseng.com/collections/mustang-gt-v6-ecoboost
Thanks! And yes sir, on the stock shifter. Feels much less notchy with the weight and the shift changes are with more "authority" if that makes sense.Wow. That's a beauty! 1.4lbs seems super heavy for a shift knob. Are you on the stock shifter?
Yeah, that makes a lot of sense. Do you ever feel like your forcing the shift or that the lever is being strained?Thanks! And yes sir, on the stock shifter. Feels much less notchy with the weight and the shift changes are with more "authority" if that makes sense.
I haven't had an instance where I felt like I was forcing the shift with the Raceseng knob. In a weird way, I felt that with the OEM knob. Probably due to the notchiness. The weighted knob makes the shifts quite a bit smoother to me.Yeah, that makes a lot of sense. Do you ever feel like your forcing the shift or that the lever is being strained?
This has been helpful. Thanks a lot. You're really selling me on it hahaI haven't had an instance where I felt like I was forcing the shift with the Raceseng knob. In a weird way, I felt that with the OEM knob. Probably due to the notchiness. The weighted knob makes the shifts quite a bit smoother to me.
I haven't felt like the lever is being strained but I get where you're coming from. I was concerned with the weight having an effect on the syncro's, kind of like how they tell you to not rest your hand on the shift knob while driving to keep the pressure off. I did a lot of research on weighted knobs and didn't find many instances where this was an issue. I decided that the benefits out weighed the risk for me so I pulled the trigger. I've been very happy with the results so far.
