Setting the vert for road racing and drag racing
Derek's GT
Palm Coast Florida
Derek
2016 Mustang GT Premium Convertible
I've added a BMR K brace, and it has a strut tower brace. I've ordered the Steeda jacking rail, and SR lowering spring. Eventually ill get struts, shocks and better sway bars. Has anyone completely added all suspension bolt ons to their Vert?
Copperhead73
Knoxville, TN
Derrick
2019 Mustang GT Premium Convertible PP1, A10, Mag, B&O, A/E, S&S
I didn't get the car until the weather had turned so can't really comment on how much any has helped. It does feel much stiffer from a chassis standpoint, however. Below are the mods I have done for chassis/suspension.
J&M Jacking Rails, Steeda dual rate MagneRide ultimate handling springs, Steeda rear control arm spherical bushings and IRS alignment kit, Steeda G-Trac Extreme K-member brace, and Steeda vertical links.
Derek's GT
Derek's GT
Palm Coast Florida
Derek
Very nice set up! Have you considered SCCA? I did solo events when i had a 95 M3. I might give it a try.
Sigster
Alpharetta, GA
Sig
2018 Mustang GT Convertible
I did the Steeda "Comfort suspension" which completely changed the way my 2018 GT vert drives. Lowering springs and new shocks/struts. No need for anything else if you are not racing it. The only thing I'd do different next time - 3/8 inch spacers on the rear springs so it doesn't drop as much as the front. Lots of weight in the back of our cars, and the spacers in my opinion would give the car a better stance.
Copperhead73
Knoxville, TN
Derrick
I don't know what I am going to do...I keep having delusions of grandeur. I think I want to put a mild blower on it, so I wanted to try to get ahead of wheel hop. I suspect if I do I will be kicked off the local 1/8th on my first run because I don't have a cage.
I don't think I would go as far as SCCA, but would like to do some open track days...where I will probably be kicked out too for not having a cage.
Derek's GT
Derek's GT
Palm Coast Florida
Derek
Im looking at finding a 4point cage. Also looking a rear seat delete. Know of any?
Copperhead73
Knoxville, TN
Derrick
tj@steeda
Timothy
Full suspension on my Steeda White Carbon Edition Q500 -
  • Steeda Pro-Action Performance Tuned Struts & Shocks (Fixed)
  • Steeda Billet Aluminum Front Sway Bar Mounts
  • Steeda Billet Aluminum Rear Sway Bar Mounts
  • Steeda Adjustable Rear Toe Links
  • Steeda Billet Aluminum Vertical Links
  • Steeda Extreme G-Trac K-Member Support Brace
  • Steeda Strut Tower Brace
  • Steeda Bump Steer Kit
  • Steeda Camber Plates
  • Steeda Billet Adjustable Rear Camber Arms
  • Steeda Rear Control Arm Spherical Bearings
  • Steeda Dual Rate Springs
It handles phenomenally ... the car was good without the upgrades, now, its a beast!
Sigma6
NC
Jay
02’ 360, 06’ GT, 11’ GT500, 15’ 911, 17’ 350
If you’re getting serious about either, get a 4 or 5pt harness to strap into. It’ll keep you from sliding when you shouldn’t be :)
Copperhead73
Knoxville, TN
Derrick
Is there somthing out there that will hold you in a factory seat, that doesn't require a bar across the back?
ManyfordsnoMustang
ChiTown
Steven
2019 Mustang GT convertible Magnetic 10 spd auto loaded; '04 Maruader SC, 1970 442 W30 Convertible, 2014 Fusion Energi
When you say it changes it, what do you mean? Seeing I bought a convertible I don't' expect it to be incredible at cornering but if it can handle better while staying comfortable it is something I may look into eventually as well.
Sigma6
NC
Jay
look into a Schroth QuickFit Pro Harness. Think this is what you’re thinking of.
Copperhead73
Knoxville, TN
Derrick
That is exactly what I was hoping to find! If/when I go with a roll bar I will go with a traditional setup, but was hoping to find something for the interim. Thanks!
Copperhead73
Knoxville, TN
Derrick
Argh! They say specifically on their site they don't work with 2018 mustangs! WTH!?
Sigma6
NC
Jay
I’d call and ask? I personally haven’t used it (I use a bar) but I’ve seen guys at Autocross use them and that’s where I first saw em a couple years back.
