Seriously? How does one get a paint chip right HERE??
Fatty
SW FL
2016 gt PP, 16 Explorer 3.5TT, Roadking
@Fatty
When you say "many layers later", do you mean that you performed the DrColorChip process as many times as required to get a flat-filled chip?
I can't seem to get the results they do in their videos in just one step. :frusty:
Yes, I did multiple layers over time. About 1 layer a week. This gives it lots of time to dry... so it doesn't keep pulling the paint out of the chip.
Souldriver
NY
2016 - Guard GT Prem. PP
my old car had a chip in that same spot. If it makes you feel better today I walk out to my dad using the weed whacker right next to my car. There are a good 4-5 new chips spots and when I got out it was covered in dust and dirt bc the ground was so dry. but you know its fathers day so cant get mad.
LETHAL
From the D but in the NC
Asheville, NC
Kevin
2018 GT A10
I have one right under the driver mirror. Then at the track the other night, I see two, side by side, on the pass side, just below where the wheel well flattens out toward the door. WTH.
Notes
Moustang
Belgium
BLACK S550 EB/AT/PP/EU
It's amazing to see where you can find some rock chips, did a big wash yesterday and found a whole bunch new ones... apart from the body alignment and a few factory dents in my front fender ... the paint quality is my biggest disappointment about this car.
None2Slow
Nampa,Id
2016 GT Premium, Performance package
I have a crap load right in front of the rear tires. Rocks getting kicked up by hte fronts and passing down the side of the car. Its horrible.
Notes
Moustang
Belgium
I noticed those as well, and I'm wondering if splash guards would help preventing this...
Jasber
Corinth, TX
Jason
2015 Mustang Ecoboost Ingot Silver
You're lucky if you only have one. I seem to get a new one every day with all the construction work in the DFW area!
Moving-Shadow
Atlanta
2015 MGT
I have a black GT with the performance tires. They pick up the road and throw it against your car! I have the same issue, tiny chips between the end of the door and the rear wheel. I picked up some guards online that protrude a small amount behind the front tires. This should help deflect gravel from following the body work.
Also, 3M make a clear covering. I put some small squares in key areas. You can't see them unless you know their there.
RpI is where I got the guards
Hope that helps.
Lost
Upsate NY
2016 GT Premium 6 speed blackout /3.55
I have one in the exact same spot.
