Select-able Cam Timing part of the performance pack?
alexx205
Germany
2012 Mustang GT
You will need to remove the catalytic converters if you don't want them to melt and clog the exhaust after a few thousand miles.
So the Boss with Track Key has no catalytic converters? Or what is the difference there?
Thanks.
Grimace427
NoVA
2011 Mustang 5.0
Thanks.
The Boss's track key is so mild it doesn't affect the cats. When you get into a real cam tune it dumps a lot of unburned fuel out the exhaust so it is very dangerous to the life of the cats.
alexx205
Germany
2012 Mustang GT
Ok, thanks. But the Boss sounds pretty good idling with Track Key anyway. So just for the sound, a mild tune would be sufficient - good to know :)
S550Boss
2016 GT350; 2018 Focus RS
And the Boss Track Key makes no appreciable difference in HP or torque numbers. Whatever it's doing for me on the road course is tough to determine without back-to-back comparisons. I know it's different from driving with my plain key, but it's difficult to quantify. I agree that there should be a switch to turn it on and off.
The other thing this needs is a far more sophisticated traction control system. Dare I say "competition mode" or will the Corvette haters get riled? Because it does work very very well there for them.
Hi-PO Stang
Minnesota
2014 Shelby GT500
:clap2:I am in the same corner as the OP. I want a switch to flip to change the cam phasing.
Zshazz
North Carolina
2015 Fiesta ST
The other thing this needs is a far more sophisticated traction control system. Dare I say "competition mode" or will the Corvette hates get riled? Because it does work very very well there for them.
I fully agree with this. There's so much potential for computerized stability control, but it's wasted. Most (all I've personally driven) could be better described as a vehicle performance limiter, when it could/should be something that enhances the overall capability of the car (improves turn-in and allows the driver to better correct oversteer without losing as much speed, etc). It's no wonder people just switch things like that off when having fun at the track.
alexx205
Germany
2012 Mustang GT
Why? So when the switch is off your engine makes less power than stock?
Probably because you can have better fuel economy while cruising and a little bit extra power and a nice sounding idle with the flip of a switch when you want that. I definitely would like that.
Grimace427
NoVA
2011 Mustang 5.0
Ti-VCT already allows that all the time without the need for flipping switches. The system is constantly variable.
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
Must be the choppy-sounding idle they're looking for that'll impress all those people who don't know what it really means. Those who do know will just shake their heads a little.
Norm
alexx205
Germany
2012 Mustang GT
I welcome you to teach me in this Ti-VCT a little, but I would think the variability of the system is dependent on various parameters/driver inputs, that are stored in the software. So you could get two different "profiles" for the timing variability by flipping a switch.
Isn't that a part of what the track key for the Boss does? (It likely changes more than just timing...)
Norm
It is not about impressing people or not knowing what it does. For some people it is not just about performance, no matter what a car looks or sounds like, but about sound (and look), too.
For example, to me, the sound is pretty high on the list of the most important things in a car.
And am I right in thinking you will shake your head over a Boss with activated Track Key?
No hard feelings.
Alex
Grimace427
NoVA
2011 Mustang 5.0
There is plenty of research you can do on your own regarding Ti-VCT.
www.youtube.com/watch?v=FWXdISsxrlw
http://en.wikipedia.org/wiki/Variable_Cam_Timing
http://www.fordmuscleforums.com/2011-ford-mustang/496202-ti-vct-engine-technology.html
www.at.ford.com/news/.../ti_vct_engine_technology_fs.pdf ‎
The bottom line, variable cam timing allows maximum performance, fuel efficiency, and driveability, all at the same time. No flipping switches are necessary.
Rickycardo
Bolingbrook, Illinois
2015 GT auto
Now that we have that all discussed out I have 2 questions: What is the consensus of what the driving mode switches will do in regards to engine performance, if anything? If Ford has the engine set for maximum performance, fuel efficiency and drivability how do ECM tunes improve on this?
No arguments, just seeking information.
Grimace427
NoVA
2011 Mustang 5.0
Driving modes change pre-selected traction control and steering settings, plus change throttle response. Engine performance is set to the maximum Ford is willing to offer with a warranty. Aftermarket tuners are not as restricted as Ford OEM so they are allowed to extract a bit more performance from changing the tune.
