sagging rear springs
dirtwarrior
kentucky
Joe
2015 3.7 mustang
my rear is sagging a bit
need to lift it about an inch
good but le3ss expensive best
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
thank you
RiotfunK
mass
Binx
22 mustang GT Premium PP1 Manual
illtal
Go steeda here.
Steeda spacers are billitt aluminum. They will not fail. You will still have to unload the suspension completely to install those plastic ones. Read: you have to disassemble the rear enough to lower the cradle that the spring sits in. Same thing you would have to do for either of these installs.
ORRadtech
Atlanta, Georgia
Go steeda here.
If the springs truly are sagging, as in have gotten weak, and you have to go through all that, why wouldn't you replace the springs? It seems to me that putting spacers onto weak springs is a bandaid and a poor one at that.
illtal
That would be what I would do, but in this case he wants a cheap fix. However in any case the amount of work is the same. I would determine first of indeed the springs are bad which would mean removing them and checking the spring height. I would also check the shocks as well.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
The springs are not any weaker than stock, I carry my walker which makes the rear a little lower. I should have mentioned that first.
ORRadtech
Atlanta, Georgia
In that case, have you considered helper airbags. How much they "help" is controlled by air pressure which can be supplied by a home/portable air compressor or a small on-board compressor. Many don't need any disassembly to install.
mindo389
Louisiana
Charles
2015 Mustang GT 5.0 50th AY Appearance Pkg.
The Steeda spacers will work, that's why they are recommended with convertible's. You may want to call them and they'll make their recommendations.
S550HPP
PDC
2022 HPP Vert
Bilstein B6 shocks will help.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
I have that is why I why I had a thread about inner diameter and unloaded length. There is a mayjor company selling the bladders at a good price
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
How much does the walker weigh?
