S650 front control arm in S550?
GTV6
OR
2017 Mustang V6 3.7, 2019 Mustang GT 5.0 PP2
Does anyone tried install s650 front control arm to S550? fit?
ORRadtech
Atlanta, Georgia
I'm sorry, I don't have an answer for you.
I am curious why you would want to use a 650 arm though? Is there something special about a 650 arm vs a 550 arm?
GTV6
OR
s650 replace front control arm from Steel to Aluminium. It should be lighter, and maybe better. My current Stang`s stock one got 10 years old now. I`m thinking if the new one works or not.
S550HPP
PDC
2022 HPP Vert
Good question OP!!
Anyone3505
behind you
20 GT 401A 6MT Convertible, 22 GTI DSG, 03 WJ Grand Cherokee Overland
I'm generally interested in parts Ford improved good the s650 that are compatible with 550. Following.
ORRadtech
Atlanta, Georgia
Makes sense. Thanks for the response.
GTV6
OR
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
It saves a couple of pounds, still need to install spherical bearings in the arms to eliminate the caster changes. Yes the 2022 knuckles have better steering geometry, and a stiffer hub.
What is "better" about it?
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
The Knuckles on March 1, 2021+ later builds utilize a longer steering arm that improves steering geometry, gives more leverage to the steering system for higher loads, the bearing is also much larger with more surface area, the knuckle itself is also more robust. Everything is improved over the prior generation mag-ride knuckles.
GTP
Deutsche Pony
Indy
Philip
GTP
Deutsche Pony
Indy
Philip
I knew this about the recent MY builds. But I put GT350 brakes on my GT so I need to lay in this new bed that I built going forward.
I guess I still don't understand what is better about the geometry. I can visualize a different camber gain geometry, but not for anything involving steering. Maybe a shorter offset between the arm ends?
Duh, I turn the wheel and my car steers, haha.
