S550 Issues
Vince
London
Vincent
2020 Mustang GT
You have described perfectly a noise i had noticed recently, and mine has 17,000 miles on it now.
Took my GT into Ford today to have the winter tyres fitted and for them to have a look at a rattle that had developed near the front drivers side wheel when going over uneven surfaces or imperfections in the road. Also noticed a bit of a 'clunk' when coming to a stand still in slow moving traffic or when releasing the brakes.
Turns out it's a failed ball joint on the control arm. Only done 18k miles, and no suspension mods.
Covered by warranty and should have the car back tomorrow.
I had a similar noise with added squeaking. Took it to ford and after 2 days diagnosed a defective shock. As car had 600 miles and im im anal about potholes ii doubted it,b they are the professionals so hey ho. Waited 3 months for a shock to arrive since apparently they're all on back order. Neadless to say i was right and noise still there. Since in lockdown and im very very bored, i jacked up the car to have a look. Took me 5 min to find i have a collapsed nearside motor mount. Have to wait til ford reopens to have it seen to now. Found some Granatelli motor sports mounts that have good reviews and are not to stiff, i will fitting those once ford do their job right.[/QUOTE]
Zapnut
Reading, UK
Hi All,
New here but I've had my S550 since 2018. Recently the drivers side window has been going a bit haywire.
I know its supposed to drop slightly when you open the door to clear the window seal, but it seems to be randomly dropping and raising while I'm driving down the road or even just sat stationary! A couple of times I've come outside to find its still down a smidge too.
Any advise would me much appreciated.
Cheers
Eclipsar
UK
NFG Mustang GT
Hi All,
Cheers
This usually fixes it
Reset Procedure
  1. Start your Mustang.
  2. Close all the doors and windows.
  3. Open the window by pressing and holding the window control switch. When the window is fully open, keep the switch pressed for a few seconds.
  4. Close the window by lifting and holding the window control switch. When the window is fully closed, keep the switch held for a few seconds.
Zapnut
Reading, UK
Reset Procedure
Cheers will give this a go!
MarkM
NI
Mark
Hi All,
Cheers
I had this too and it was driving me mad, window would go up and down when driving! I removed the door card and pulled all the plugs, made sure all pins were pushed into each plug fully, put everything back together and it’s been fine since, so obviously had a poor connection somewhere!
Zapnut
Reading, UK
Yeah I tried the reset with no luck so I think this is my next option.
I'll have to get in there and take a look.
Hopefully taking the door card off isn't too much of a pain!
andyturbo2000
Lincolnshire
Andy
2016 Ecoboost Convertible
Evap core failure.
aircon goes gradually warm. It’s a dash out job as it’s between the dash and bulkhead. 2k fix without warranty.
rear calliper seized.
Takes out discs, pads and fluid. Around £700 without warranty. Both sides failed with me at different times.
rear camera failure.
Warranty will fix this but it’s simple to fix. Strip back the loom on the inside of the boot lid. You’ll find the offending wires easily enough.
puddle lamps.
Early ones lose the logo due to paper gobos used. Warranty will fix but only £40 ish if not.
corrosion everywhere.
Boot seems rot, bonnet rots, wings rot. All covered by the 12 year perforation warranty
Manual gearbox crunch.
some say synchros but I’ve had my gearbox rebuilt and it’s exactly the same. Crunch when cold in 2nd moving up the gears. Mustang techs say the same “a character of the box”.
GR11M
Herts, England
Graham
Ford Mustang GT
Window motors
They get wet and either stop working or work sporadically. The fix is to dry them out but a replacement motor is about £60 from the US. Replacement isn't too difficult, It requires taking the door cards off and the motors are unique per door.
Door actuators
The motors wear out and it stops opening or closing the flaps resulting in hot air coming from the wrong vents or not at all. There's 4 actuators under the dash. It's an easy replacement and only costs around $28 each - avoid Ford UK they sell them for £85 each.
raptor17GT
Scotland
Mustang GT Manual 2017 - now sold ☹
Ford UK are crazy expensive for parts, my only worry is pattern parts from the US (or anywhere for that matter) not being good and failing off the bat :(
