Running e85 on stock car
Niz55
Us
17 GT350
My car is back to stock down to the filter. I still have half tank of e85 left. Would be safe to run it until I fill it with pump?
18psi
of boost
Best Coast
On stock tune? Nope
Niz55
Niz55
Us
17 GT350
Yep stock tune. I guess I have to empty it some how and fill it with pump.
Niz55
Niz55
Us
17 GT350
Tried jumping the relay with a hose attached to fuel line but no luck. Starts and shuts off.
I tried cranking it 3-4 times and it gives me "crank exceeded" warning. Going to buy a pump tommorow and suck it from the tank
Ramen
Ft. Lauderdale
2015 Mustang GT Premium
Fill it the rest of the way up with regular gas and drive off the E85.
Keep filling it up to dilute the rest if you'd prefer.
GTBOB
Fairfield Township, OHIO
Bob
'18 GT, Royal Crimson, 10 speed, Active Exhaust
What he said. You will be fine. The car will compensate enough that you will not have any ill effects. Just avoid prolong WOT situations.
Which brings up a good point...When buying a used Mustang, can have the dealer scan the ecu and look at the key-on cycles This would tell you real quick if it had a tune in its life. "umm yeah, it has 22k miles and the ignition has only been cycled 5 times" lol:lol: Remainder of factory warranty=gone:)
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
Just drive it out like the other guys said. Our cars run in closed loop all the time, so the ECM will correct the fueling by adjusting the fuel trims.
