Rim specs help....
The Demon
Brett
2022 Mach 1 N5809
Glad I just found this thread in my search. I was driving myself crazy looking for wheels. I wanted to keep the staggered and now I think I was nuts for thinking that. I had already replaced my rear tires with 275/40/19 so I will just do the same up front and be square on the 19x10 E35. Every wheel I was looking at would not fit due to the Brembo's.
The Demon
Brett
2022 Mach 1 N5809
19x10 et.35 all around
275/40/19 on all corners.
Perfect
Dumb question but does it have to be exact? Can I use 19x10.5 +40?
blind*guardian
Reseda, CA
2019 Mustang GT
That will most likely rub on the strut in the front. Everything is very tight up front; not a lot of room there. Will work if you use a small spacer, maybe 5-8mm. Those don’t need extended studs and are fairly cheap.
Chef jpd
Brooklyn, NY
I think it will depend on if it clears the front strut.
blind*guardian
Reseda, CA
2019 Mustang GT
Would a 20-10 wheel with 1.88 Inches, 48mm off-set work up front with a 275 or 285/35/20?
Too much offset, will rub. Will need a small spacer, at least 8mm.
The Demon
Brett
2022 Mach 1 N5809
I really like those Niche Essens in this thread. They have 19x10 +40
blind*guardian
Reseda, CA
2019 Mustang GT
19x10 et 40 will work. As I said, I have two sets of wheels, one is et40 and it still clears, but just barely. I was somewhat concerned about deflection and rubbing at high loads, so I've been running that with a very small 5mm spacer. A very small spacer like that definitely has no impact on reliability/safety and you can probably just run it without a spacer and see if that works. If you ever notice rubbing, just add a small spacer.
ChitownStang
Chicago, North Shore
2021 Mach 1
These are the exact specs I mentioned above
Niche Essen 19x10 et35, Conti DWS06 275/40/19 all around.
Stock Magneride height.
20201204_114251 by chefjpd, on Flickr
Same setup on my 16 EB PP
Screenshot_20180802-064709_Samsung Experience Home by chefjpd, on Flickr
This looks great!
I had the 19" Niche Essens on my 15GT Staggered.
I think I will take your advice and do the 10" squared with 275 DWS's on my Mach 1 for the winter.
How are the DWS all seasons in the cold?
Chef jpd
Brooklyn, NY
This looks great!
They work great in the cold and rain.
Never really used them in the snow, so can't comment.
I love these tires and the newer version is probably even better.
