Reverse lockout collar broken-help needed
user727
Virginia
2020 GT PP1
Installing redline e brake and shift boot leather, broke a tab on the white reverse lockout collar. I need to replace that part but cannot remove without removing the pin holding the spring in place (yellow arrow in pic). How do I get that pin out? Is it pressed in? Is it screwed in there? I’m stucI and hesitant to break more parts. Thx in advance.
user727
Virginia
2020 GT PP1
Can I put that pin back once it’s been removed?
Is there a better way to fix the broken tab on the white collar?
user727
Virginia
2020 GT PP1
Thx but that video doesn’t cover this issue.
I need to replace the white plastic part below the Barton billet piece- the part that “receives“ and holds the Barton.
or I need a better way to fix this issue, JB weld the aluminum to the plastic??
JJSSI
St Simons Island, Georgia
Jim
2020 EcoBoost HPP w/Handling Package, 2004 Boxster S, 2013 Jeep JK,
Maybe get the part from someone who has replaced their shifter with an after market shifter.
I don't think epoxy will hold.
The pin comes out with a hammer and punch and can be reused.
user727
Virginia
2020 GT PP1
Wait, watched the cj video ton the hurst shifter install. That video shows the pin being pressed out of the sfifter with a C clamp. I’m good now, should be able to replace the plastic part. Whew...
BeastAR
Arkansas
Josh
2019 Shelby GT350R
Awesome. Figured there was a video on CJ's, just couldn't see them to get you the right one. Next ones I was going to suggest were short shifter installs
Pwny_Exp
NorCal
Jake
'20 GT PP1, '18 Power Wagon, '16 JK, '19 E-Golf
Hey OP, where did you end up sourcing your broken collar piece? I broke the same tab on mine yesterday removing the lockout collar/shift boot.
user727
Virginia
2020 GT PP1
I got the white plastic collar and the entire stock shifter from a forum member- he sent the leftover stock parts after his upgrade. Whole deal $30, saved my ass.. Should be another member out there that can hook u up. Lots of folks upgrade. Ford will only sell the whole shifter. Head to the. Classifieds..
Pwny_Exp
NorCal
Jake
Much appreciated! I'll hunt the classifieds. I was only coming up with the entire shifter assembly for like $300 from Ford and swore I was missing something. At least I now know it's as absurd as it seems.
Sabre
Iowa
Iconic Silver 2023 Mach 1 with Handling Package
You just need a roll pin punch that fits the pin correctly and tap it out.....it can be tapped right back in place.
