Resonator placement?
Miichaelo912
Houston tx
2015 mustang v6, 2017 mustang gt
I currently have borla atak with xpipe. I like the tone for the most part but would like to cut some of the rasp. I bought some dynomax small bullet resonator/mufflers to calm the rasp. My question is, does placement of the resonator matter? I've seen people say put it right after the xpipe like connect it with the xpipe and others say the closes to the mufflers. Which will only help the rasp and not quiet down the whole thing? Thanks
hiccup
Kentucky
2015 Mustang GT black base PP RECAROS
I'd go right after the Xpipe instead of close to mufflers..
hiccup
Kentucky
Have you had any experience with different spots?
No..have only removed the stock resonator suitcase in place for an Xpipe but the fact that Ford kept it upstream from the mufflers says something to the science of it..
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Or just that it packages best there.
AZ18yote
Arizona
Bryan
I did similar with Vibrants on my ARH LTH to Corsa Xtreme setup. Right after mufflers before x. Based on the pic below.
Miichaelo912
Houston tx
I saw your comment on another post like mine. I couldnt tell if i want it like yours or like almost connecting to the xpipe i have on currently. I just want to know if theres any difference lol
FruityJudy
South Alabama
2018 Mustang GT A10
Has anyone ever deleted the cats by cutting them out and welding vibrants in there place?
Ebm
North Carolina
Guy
'14 GT
My resonators are right after the x-pipe. There's a little bit of a straight away.
I'd say get high flow cats instead of deleting the cats. The smell gets old after awhile. Just my .02 though.
AlmostFamous
I have an X-pipe and those mufflers, dynomax race mini bullets, 6 inchers. They are welded directly after the X-pipe, before the axle. If you have the 6 inch dynomax bullets, they’ll fit perfectly right after the X-pipe with zero modification needed. If you have the 9 inch bullets, they should fit in that location without issue as well.
AlmostFamous
Did the race mini's do much for sound control ?
Sound control as in quality of sound? Yes, cleared out all the unpleasant rasp and harshness, especially after 4,000rpms. Night and day difference in the upper rpms. Also, deepened the exhaust note and added some tone. No mufflers was just a little too raw sounding for my taste. Now, the exhaust note is full. Yet, it sounds just as loud and as aggressive as before. If you’re looking for sound control as in dropping the decimal level, dynomax has 12 and 18 inch bullet mufflers that are much more effective in that regards.
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
Are those 1794's? Twelve inches long correct?
AZ18yote
Arizona
Bryan
