Replace Oil Pan Gasket!
Shadow277
Arizona
2016 Mustang GT 2012 Corolla
For those who read my last form about the car smoking, the tech at Firestone said there is a tiny leak in the oil pan. He recommends to change the gasket. His shop doesn't have an engine lift so he cannot do the job.
Is there a way I can do this at home? Should I just take it to Ford?
EFI
Masshole central
5.Br0
If you have to ask, yes you should take it to Ford.
You have to lower the subframe and support the engine separately to be able to get to the entire oil pan.
KingKona
Virginia
Shlomo
2019 GT
There's a leak in the oil pan??? Or the oil pan gasket????
Either way it should be doable with jacks and such, but if it were my I'd order the parts and pay a mechanic to install them.
Shadow277
Arizona
That's what I figured... Crap, and I just bought a new battery for my 2016 too.
Shadow277
Arizona
If Ford says they have an OEM gasket. I read on here the frlpro or whatever is trash. Unless there is something better than Ford OEM?
Shadow277
Arizona
Anyone who made need this in the future, I heard some guys on Youtube found loose bolts on the head. I will check the oil pan too and ensure it's all at spec. I mean, if it was still an issue then I should still have smoke.
Sounds dumb to check but there has to be a reason why only SOME oil leaked and not constantly. I do NOT leak oil in my drive way.
DougS550
Fishers, Indiana
Doug
I haven't looked at the IPB but I would think the gasket would be silicone/rubber. I would re-torque the bots, then spray with carb cleaner to remove all oil residue, then see how it goes.
Shadow277
Arizona
Fantastic idea. I'll do that and if I dom't spot anything next oil change (4 months from now), I will report that.
KingKona
Virginia
Shlomo
2019 GT
You gotta be paying more attention than that.
A big piece of clean cardboard under the car where it's parked to spot for leaks, and checking your oil levels every few days.
Can't be messing around with oil levels/leaks.
DougS550
Fishers, Indiana
Doug
If it is a leak sure, but if it's a seep, then clean re-torque and recheck. Always check oil levels but seeps don't drain the tank so to speak. The old saying is, when you can't stand to see the oil spots on your driveway, start replacing seals and gaskets, otherwise live with it. Just saying. Good luck to the OP
Shadow277
Arizona
I havr an empty box from diapers for my 1 year old. I plan to use that.
Shadow277
Arizona
Saw a Youtube video suggesting that inspecting valve cover bolts, specifically on the driver side, was the fix. Lo and behold, my bolts were loose enough to take off with just my fingers.
I retightened the two bolts and checked the passanger side too but those were fine. I still tightened them a bit more. So for whoever is interested or some poor guy in a few years, this might be your answer too.
I will let ya'll know at the end of this week.
Thread containing the valve cover TSB:
https://www.mustang6g.com/forums/threads/valve-cover-leak.131014/#post-2705151
Instructions for L & R valve cover R&R:
https://www.mustang6g.com/forums/attachments/5-0-valve-cover-rh-pdf.401025/
https://www.mustang6g.com/forums/attachments/5-0-valve-cover-lh-pdf.401026/
Shadow277
Arizona
I didn't mean for this to become a valve cover thread. I really thought it was the oil pan, as per my trusted mechanic. Thank you for the helpful threads though.
