"Replace Key Battery" warning still appearing after recently changing the battery (2016 V6)
kingratS550
Lakewood
Dyl
2016 V6 Mustang
Hey all,
A week or so after I bought my Mustang I got a notice on the dashboard that my key fob's battery was running low and I needed to replace it.
I did so, using the correct, new batteries in the correct orientation, as described in the owner's manual.
For the following couple weeks there were no more notices regarding the fob.
Yesterday, however, I got a notice again. I opened up the fob and reset the batteries with the notice still appearing.
Has anyone else encountered this and is there anyway to fix it/confirm the batteries are not low?
Thanks!
dburgjohn
Dyersburg, TN 38024
2016 Mustang Coupe V6
I found this:
If the "Replace Key Battery" message persists in your Ford Mustang, it is usually because the vehicle requires a specific, often rapid, number of drive cycles to detect the new voltage or because of a poor-quality replacement battery. Common fixes include ensuring the correct polarity (+ side up), cleaning the terminals, or resetting the fob by holding the lock/unlock buttons simultaneously for 15 seconds. Here are the specific troubleshooting steps:
1. Simple Resync Method (Recommended First Step)
Get inside the vehicle and close all doors.
Press and hold both the lock and unlock buttons on the key fob simultaneously for 15–20 seconds.
Alternatively, turn the ignition on and off rapidly 6–8 times to prompt the car to recheck the fob.
2. Verify Battery and Hardware
Battery Orientation: Ensure the positive (+) side is facing up (away from the circuit board).
Battery Quality: Ensure you used a new, high-quality CR2450 (newer Mustangs) or CR2032 (older models) battery. Some users on Reddit report that cheap batteries, even new, cause this error.
Bent Terminals: The metal prongs inside the fob may not be touching the battery tightly. Gently pry the metal prongs upward to ensure they make solid contact with the battery, as suggested in Reddit.
3. Check for Interference
Ensure a second key fob isn't nearby causing interference.
If you recently disconnected your car battery, the car's computer may need to be reset.
4. Cold/Delayed Sync
If the battery was dead for a long time, the fob may need time (up to 2 days) or consistent use to re-pair with the car, according to Reddit users.
If the error continues, the key fob may be damaged, or the car requires a dealer diagnostic tool.
69mach1-395
central nm, usa
2016 RR GT/CS
I have had this issue at times. Usually, a sharp rap of the fob will provide for better contact of the batteries and I'm good to go. Unless the batts are run down again...
kingratS550
Lakewood
Dyl
2016 V6 Mustang
I found this:
Thanks! Yesterday as I walking to my car after work I held down the lock button as I heard that worked elsewhere. I haven't gotten the message since.
If it happens again I'm going to try the methods you listed. Your list is pretty concise so I hope this thread helps whoever has this issue in the future.
Thanks!
