replace door speakers
dirtwarrior
kentucky
Joe
2015 3.7 mustang
My door speakers buzz a little so replacing them with 6.5 inch 3 way speakers. I have the standard 4.2 inch display. Do you think I will notice much improvement in sound quality
Emilbadal
Socal
Emil
2016 V6 Auto DIB
It depends on what you replace it with. Since you're not using aftermarket amp, try looking for a speaker that has 90-93db per watt per meter sensitivity and also it's power handling is low. Something that has power handling of max 25-45 Watts RMS. The factory amp is weak and going for high power handling speakers will have the inverse effect of what you're try to achieve. Also maybe consider either 2-way components that have in-line crossovers(like the factory) or 2-way coaxial and then disconnect the factory tweeter. 3- way coaxial are kind of a gimmick.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
Thanks for the reply. I will look closely at the speakers
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
here are the spec
RMS Power
  • 200 watts
  • Peak Power Handling
  • 400 watts
  • Minimum Frequency Response
  • 65 hertz
  • Maximum Frequency Response
  • 20 kilohertz
  • Sensitivity
    90 decibels
  • Speaker Size
    6.5 inches
  • Speaker Type
    Coaxial
  • Tweeter Composition
    Mylar
  • Woofer Composition
    Poly-Injected Cone
  • Woofer Surround Material
    Rubber
IPOGT
Alan
here are the spec
RMS Power
  • 200 watts
  • 400 watts
  • 65 hertz
  • 20 kilohertz
  • Sensitivity
    90 decibels
  • Speaker Size
    6.5 inches
  • Speaker Type
    Coaxial
    Mylar
    Poly-Injected Cone
    Rubber
The most important aspect of your choice besides the size for fitment reasons, will be the IMPEDANCE required by the amplifier to see as its load. The factory radio has requires a low impedance load. 8 ohm typical speaker would have no volume and poor response. Maybe someone can chime in with the impedance requirement for the front door speaker with your particular factory option radio. If the radio is looking for a 2 ohm speaker for instance, try to find one as close as possible for the best result. Almost anything aftermarket will sound better than factory as long as you mind the above.
here are the spec
RMS Power
  • 200 watts
  • 400 watts
  • 65 hertz
  • 20 kilohertz
  • Sensitivity
    90 decibels
  • Speaker Size
    6.5 inches
  • Speaker Type
    Coaxial
    Mylar
    Poly-Injected Cone
    Rubber
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
Thanks
I found so infinities with 2.3 ohm and 94 on semsitivity
BadHabit2Break
Houston, TX
Stephen
2017 Ford Mustang GT350
Just my 2 cents....
If your keeping the stock amp and are doing a speaker upgrade, the above mention about the low wattage/high db sensitivity is correct. You will also want to make sure the ohm is just the same or really close. If you replace a 2ohm speaker with a 4ohm speaker, volume will be less as you are cutting the wattage in half.
Alot of manufactures are creating speakers with the lower/higher ohm for OEM replacements.
What OEM audio system do you have (9 speaker, 6 speaker)?
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
I am not sure what speakers ford put in the standard 4.2 inch stereo
Emilbadal
Socal
Emil
2016 V6 Auto DIB
@dirtwarrior the Infinities that you found are your best bet. I agree with the other two members, regarding the impedance. I didn't mention it, because 99.9% of the consumer products on the market are 4ohm and below. The base speakers are 4ohm midrange and 8 ohm tweeter if I remember correctly hooked to each other in parallels. If I knew what I know after installing aftermarket amps and active subwoofers and stuff, I would simply put the Infinity speakers in and be done with it.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
Counting the tweeters? There is 1 on each corner and center. Where is the other 1
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
No center speaker in the base 4 inch stereo.
2 door woofers, 2 tweeters in pillar, 2 rear deck speakers = 6.
dirtwarrior
dirtwarrior
kentucky
Joe
2015 3.7 mustang
If I get quality speakers. Will I get a big difference in sound?
