Recommended tests prior to tuning the engine?
Simon.V8
IL
Simon
19 Mustang GT
Hello,
I am a new mustang owner of a 19 Mustang GT and I was curious if there are recommended or essentials tests people perform prior to modding/tuning the 5.0?
How many miles should I put on the engine before modding it? (5K+?)
So far I was recommended to perform a borescope & a compression test, please feel free to chime in or provide links to something you think would help!
Thank you.
Kong76
Turlock, Ca
2016 Ingot Silver GT
This is a decent question because once you tune the chances of being denied warranty work is greater. After my experience and problems with this engine, it will probably stay stock until every bit of my 5/60k is used up. Tune resets the key count so there's no getting around it.
qbnlynx
phoenix
ralph
2019 mustang gt pp2
I would only modify if your ready to pony up for out of warranty maintenance costs. I've seen people throw superchargers on with less than 1k miles and have no issues though
Ebm
North Carolina
Guy
'14 GT
Hello,
Thank you.
Tests on a brand new car? Yeah... the real test is to just drive it. People worry too much. Drive it for a few thousand miles at least and if everything sounds normal and it drives fine, mod it.
There is no test to do to a brand new car. This isn't a car with 200k miles on it. A compression test? LOL
NoVaGT
Northern Virginia
2019 PP1 GT Kona
This;
If you get a nice, safe tune, you should have no issues as long as you run the correct fuel. A simple canned tune is pretty safe.
....I was recommended to perform a borescope & a compression test.....
Who told you this?
ChiTownStang26
Chicago
2016 Mustang GT Premium ~2016 Mustang V6(sold)~
You can have your oil tested by Blackstone Laboratory. They will let you know if you have an abnormal amount of metal shavings in the oil which could indicate a problem youd have down the road. Other than that it's up to you when you want to tune it.
If you just bought it enjoy the car until that warm fuzzy feeling goes away, then tune it and you'll get that feeling back...
NoVaGT
Northern Virginia
2019 PP1 GT Kona
I tested mine by running it to the redline a few times on the way home from the dealer. Seemed to be working just fine, so I threw a Whipple on it.
This site should have a "Whipple That B@*ch!!" meme by now. Something to be used as a standard answer for many a question posed here.
ETA:
Here ya go!!
Also available as a coffee cup;
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
ETA:
Here ya go!!
This made me laugh just a little.
Andy13186
I just broke it in how they say to in the manual and used ceratec because I had the worst bbq tick ever (ceratec fixed it). then drove it hard for like 2000 miles over a few months to see if anything was going to break and also get used to the car, then tuned it.
18GTmustang
Houston tx
Eduardo Perez
2018 ford mustang GT
i tuned my car with few hundred miles with 0 issues as of today, after first oil change i did get the typewritter tick only on cold engine starts. Ive been lucky with all my modified vechiles . so to answer your question i would say proper breaking period if your concern about it.
but why would i give advice if i didnt even do it myself.. Enjoy your car man dont stress on things you cant control @ 100%
CrashOverride
Under a hood
2015 Mustang GT
Some pro engine builders like to start out with a "seasoned" block. Basically, one that has been run for a while. How long? Well how much salt do you like on your frys? (Everyone is different). If you are going to supercharge your car, then you should run the oil pump test. If it has an oil pump, then you should replace the gears inside the oil pump.
Kermitz
Vacaville CA
Seth
2019 Mustang GT PP1 300A M6
Been on a E85 tune since @ 750 miles. No issues, no worries and no looking back.
Simon.V8
IL
Simon
19 Mustang GT
Thank you all for the comments!
