Recaros
tmilliner24
tmilliner24
Louisville
Tony
2011 mustang, 2021 GT
My car doesn’t have that option. It didn’t come with power seats.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
You have to turn that option on with forscan then go into the menu and turn it off.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
I'm not good with forscan. Just know it can be done, as I've met a guy who added the power seats like you. I have the power seats so I wasn't interested in how he did it exaclty. It was also almost 2 years ago at a car show.
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
Get a VIN number for a similarly equipped car that has the memory package and compare the as-built line for line for differences. One of them will be the one to enable the menu option. There may be another to enable the function as well. This is how I added the rear diff temp sender and gauge to mine.
Sonicblue_5.0
Netherlands
2005 Mustang (currently V6, soon to be coyote swapped). 2018 Mustang EcoBoost PP
I’m dealing with something similar. I’m planning to do an electric base swap on my Recaros, so I bought two electric bases, one driver side and one passenger side. Recaro-equipped cars are not pre-wired for comfort seats, so I had to run everything myself, power, ground and MS-CAN wiring.
During test fitting, the first thing I noticed was the easy entry/exit movement when turning off the car. Before modifying the Recaros permanently, I wanted to make sure everything worked as intended.
I haven’t looked into Forscan yet to enable or disable the option in the cluster, but right now I cannot control the feature, while the seat still performs the movement.
When I figure out how to enable the option in the cluster (IPC) so I can turn the feature on or off, I’ll post an update.
LFSoccer2k6
STL, MO.
Greg
2023 Mach 1 Premium Jet Gray HP
Going to PM you about your recaros.
Alerch
Goose creek SC
Adam
2016 GT
I’m interested in the seats depending on price and your location.. shoot me a PM.
