REAR VIEW MIRROR BLURRING PROBLEM
superman07
columbus ohio
2016 gt350
Mine does this horribly also. its non usable pretty much except for knowing if you have flashing lights behind you. Was going to report to the dealer. Very minor pressure from my finger and it clears right up. All speeds and rpm.
it is tight as snot to the window, the mirror itself is too loose in the overall housing.
theman1990
1 arm, 4 cars, 0 autos
Tampa, FL
Daniel
GT350 Tech, GT350R
That is most likely vibration from the flat plane crank . . . some of us have it and some of us don't. Sorry I couldn't be more help.
I disagree!! My tech 350's mirror is perfect but my R's mirror is useless. I isolated it down to wheels. At high speed push the clutch in and see if there is a change. If it persists, it's not the engine. Or shut it off completely (if you dare/can).
lemers
Globetrotter
Carlisle, PA
2016 GT350
Dave99GT
Milwaukee
2014 Mustang Convertible
My 2003 Cobra had bad vibration in the mirror like you describe. Had to have the driveshaft replaced, that cleared it up. Was a common problem with 2003 Cobras.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
This is one of the symptoms of the 50-70mph driveline vibration issue.
Even though the set screw is tight, the bracket still has play with the windshield. I have not studied this further, but I suspect that filling the small gap (such as with the rubber in the video on the first thread page) should work.
Edit: My mirror mount cable comes in next week, for my radar detector. At that time, I would look into the situation closer and report back.
SROLD
SROLD
PHOENIX,AZ
STEVE
GT350
Thanks everyone for your serious comments..rubber and inside tightening look like great solutions to this problem. Will stop using all caps.
NipSC4328
Northern Oklahoma
Jim
2020 GT500 Twister Orange w\ Black OTTS
No problem, hope you get this resolved. BTW, all caps is considered shouting, hence the comments. Cheers!:thumbsup:
MTWINN
Southern IL
2017 Shelby GT350
I JUST DROVE MY NEW GT350 FROM WISCONSIN TO PHOENIX AND HAD AN OVERALL TREMENDOUS TRIP EXCEPT FOR ONE ANNOYING PROBLEM. THE REAR VIEW MIRROR HAS A SMALL VIBRATION AT SPEED EVEN ON RELATIVELY SMOOTH INTERSTATE HIGHWAYS. A QUICK GLANCE AT IT AND IT IS VERY DIFFICULT TO DETERMINE WHAT VEHICLE IS BEHIND IN THE MIRROR BECAUSE OF THE BLURRING. PUTTING MY HAND ON THE MIRROR DOES STOP IT BUT I SHOULD NOT HAVE TO DO THIS. SCREW HOLDING IT TO THE WINDSHIELD WAS TIGHTENED BUT DID NOT STOP IT. HAS ANYONE ELSE HAD THIS PROBLEM...IF SO...HOW SOLVED OR IS IT A WARRANTY PROBLEM?
OUTSIDE MIRRORS DO NOT VIBRATE AND BLUR.
Mine does not vibrate and blur image as you've described.
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
My rearview mirror has had no vibration at any speed, there has to be an identifiable cause and solution for those that have this problem
GTP
Deutsche Pony
Indy
Philip
Today I removed the dash bezel that is around the headlight switch. I applied flocking tape at several points to solve the intermittent rattle, hopefully.
So I looked into the mirror situation. In spite of the set screw being tight, the shoe plate still has slack with the windshield. So I applied some of the flocking tape along the two edges of the plate. I bet that will fix it. I will report back Monday, as that is my next freeway run.
HizliBullet
GT350
Canada
Mustang
16 GT350, 17 Edge Sport
whatever behind is in the past (mine vibrates too)
lemers
Globetrotter
Carlisle, PA
2016 GT350
Just another reason not to worry about how big the R wing is
84venom
2000 Cobra R, 2016 GT350 TP DIB w/White Stripes
So I'm not the only one with a vibrating mirror!! Thanks for putting it out there....
Zombo
befejezett
2016 GT350 Track Pack - Race Red, Blk Roof - G5405
I never noticed a resonating rear view mirror, regardless of engine RPM, until recently, when I was driving on the highway (something I rarely do in the GT350). I have to concur with [MENTION=16078]GTP[/MENTION] that it's a drive line issue, not a voodoo issue. Driveshaft or something in the rear end, perhaps.
