Rear suspension torque specs
Legionofone
2016 Mustang GT Base
Does anyone have the torque specs for most of the rear suspension, doing an install of steeda stuff and I don't have all the specs.
ForTehNguyen
Houston, Texas
15 GT
steeda usually lists torque specs in their instructions
Legionofone
I do, but they don't have the specs for the lower shock. And would like a double check if possible.
ForTehNguyen
Houston, Texas
15 GT
From a BMR installation guide
Lower shock bolts: 35 ft/lbs.
Lower vertical link bolt: 129 ft/lbs.
Rear inner lower control arm bolts: 184 ft/lbs.
Front inner lower control arm bolts: 166 ft/lbs.
Outer lower control arm bolts: 203 ft/lbs
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
Assuming these are specs for the rear control arm assemby.
** passenger side ** facing the assembly
which is rear inner vs outer? .... left or right
CrazedAntelope
San Jose, CA
Chad
Ecoboost Premium PP
Is there a book or service manual you can buy for these cars?
redline727
Thread Killer
Mooresville NC
Rocky
2021 Oxford White Mustang GT
I torqued all mine to FNtight ft/lbs not sure the conversion to Nm though...
