Heinoceros
i am still using the rear channel, and you are right, there is crazy bass roll-off going on. I am changing to the front channel anyway just because of the phone, but it sounds like you would expect the bass roll-off to be less in the front channels? I was not expecting that, i would have expected it to be identical, since the speakers are the same front and rear.You're not still using the rear channel signal for the sub, are you? I imagine that would amplify (poor choice of words) the problem. I feel like every factory system I've ever worked with has suffered from dramatic bass roll-off in the rear channel, especially at higher volumes.
the roll-off is also very volume dependent, which means when i try to add it back in via the high to low signal converter box, it just goes all wacky on me.
