Rear Main Seal Weep - Solved
S550HPP
PDC
2022 HPP Vert
Have a slightly damp area on right side of trans case. New trans done 8K miles ago. mechanic says it's rear Main Seal Weep. Warranty expires in 3K miles.
Dealer ignored it.
Something to plan for and how much would it cost approx to do a rear Main Seal or should I just buy extended warranty.
Had the car on a lift cleaned the area thoroughly and discovered a chunk out of top oil pan edge and apparent cracking near trans interface....trans was R&R twice, plus a new one. Looks like a prybar was wedged in for some stupid reason or it chuckled out on its own possibly when they did the new engine mount warranty.
GJarrett
Bradenton, FL
Gerald
2017 EcoBoost Premium
The tranny has to be pulled back out again to get to the seal; I don't know how many labor hours that is but it's a big job and will be expensive. Plus the rear main seal has a reputation for warping and developing a leak if it is not carefully installed perfectly. MAP Performance sells a rear main and housing that is more robust:
https://www.maperformance.com/produ...r-engines-ebm-rmh?_pos=1&_sid=46d25f746&_ss=r
If you've got another 3k miles to warranty I'd get it done before then. I had to get mine replaced and do not recall how much it cost, but it was not cheap.
S550HPP
PDC
2022 HPP Vert
I know Trans R&R is 8 hrs book time plus the hardware and that book time.
After cleaning the case it looks like a chunked oil pan edge, and possibly some cracking have cleaned it and will get it back on the lift in 1500 miles to check.
S550HPP
PDC
2022 HPP Vert
Upon further inspection and few thousand miles cleaned up that area that looks chinked out is actually gasket maker seepage and the damp spot was from a leaking engine mount that blew back.
Snakebyte
West Central Florida
Nathan
2019 Mustang GT Convertible
Glad to hear your troubles were bad as you first thought.
ralph7
Houston
2000 GMC Sierra 1500, 2019 Mustang Bullitt
“Leaking engine mount” makes no sense.
Skye
≈39N
"Skye" Mach1 N2144
Basspro302
Ohio
2019 mustang gt
My driver side engine mount tore and was leaking also.
ralph7
Houston
I learned something, never heard of that before.
S550HPP
PDC
2022 HPP Vert
I was never concerned still under warranty just monitoring it.
Yes I had a blow right side liquid filled mount replaced under warranty blew oil 8" X 3' strip down belly pan, after it leaked out of the pan slit, and misted that part of the block.
