SlowEldiablo
Hey everyone, just finished swapping a loaded pumpkin with a Torsen lsd and 3.73 into my Mustang that had a pumpkin with a Trac-lok and 3.31 gears. Took the first test drive and could not tell a bump in the pull of the car, seems like I still have the 3.31 gears still in the car. Also, in gears 4-6 car will not let me pass 4K on the tac, when I put my gas to the floor it just hits a spot with the power band and holds it there. Car is just not acting right at all. I did the same swap on my 2012 GT and the change was night and day. I know a tuner is needed to correct the speedometer change but is the tuner needed to fix the problems I'm having? Like I said, no notice in gear change and I know I left 3.31 to go to 3.73, car will not let me pass 4K RPM while driving, putting the gas pedal to the floor pulls the car so far up the power band then hangs there, will not power through. If anyone has any suggestions, please help.
Thank you,
J
SlowEldiablo
Thank you,
J
SlowEldiablo
