Random hard brake pedal....brake booster issues
NeedForGreen
2019 Mustang GT
I have noticed that there are days I go to start my car and the brake pedal is hard. Other times no issues. Does this sound like a stuck or bad valve? I'm hesitant to take it to the dealer for them to tell me they can't find anything wrong especially if it randomly happens. Could it be something else causing it?
lacanteen
Louisiana: Cajun Country
George
If you have a manual transmission I think the clutch shares the brake booster. If you have the A-10 it's probably a booster issue.
NeedForGreen
2019 Mustang GT
Its auto. I know it's a booster issue, but am wondering if it's the check valve considering its random.
Late Starter
VA
2017 GT Premium
I had the same problem on my auto equipped '17 GT. I replaced the check valve and still had the issue. Tried another one and problem solved.
NeedForGreen
2019 Mustang GT
Interesting you had to try 2. Was it hard to replace it?
ahl395
Allan
The check valve is very easy to replace. Just pops out of the booster and a clamp holding the hose on.
Triton54
Delano Mn.
Greg
18 GT A-10 (mine) 17 GT pp, 6spd (wifes)
Mine does this also..... 12,xxxx miles, so far i am just living with it. but that was before this news.....
NeedForGreen
2019 Mustang GT
I might just replace it myself rather then waste my time at the dealer and see if it fixes things. It's a cheap part.
NeedForGreen
2019 Mustang GT
I'm not even at 3k.
Like you though just been living with it. My research shows its pretty common.
rangerryda
2019 Mustang GT Premium A10
Mine only does it when it sits for 2 days or more (roughly). It's got 9k on it and has always done it as far as I can remember.
Rapid Red
Woodstock GA
Greg
It is only a problem if it stays hard after the engine is running.
Hard peddle tells you the booster does not have a vacuum.
As mentioned above, "it happens after the car sits for 2 days." Yup, vacuum bleeds off, hard pedal . Engine fired, pulls a vacuum all systems go.
You can make it happen every time...
Right after parking the car, engine off. Pump the brakes 2-3 times, the pedal will get hard.
Put foot on brake, and start the car the pedal, will go lower. This is the way a booster is check for proper operation.
rangerryda
My only concern is having to stab the pedal really, really hard to get the switch to engage for push button start. Otherwise, I'm familiar with vacuum brakes.
Rapid Red
Woodstock GA
Greg
HUH ? Why would you think changing the check valve would make any difference? Maybe you're not as informed about vacuum brakes as you may think ?
rangerryda
I never mentioned anything about a check valve. Maybe check the posts before you look foolish.
Rapid Red
Woodstock GA
Greg
Totally wrong, the only thing shared by those 2 systems is the brake fluid resolver .
