Radiator air deflector parts.
Jpump
Arizona
Jeremy
2019 Mustang GT Premium PP1(Need For Green)
I'm looking for some help. I recently bought a used Cervinni C Series Upper and Lower Grille off Facebook, but unfortunately, the previous owner of my car broke several of the lower grille tabs and I didn't feel comfortable mounting the grille with missing tabs, so I'm currently trying to resell it and put my stock grilles back in.
That's not the main problem though. Somehow, when I bought my car, the PPI didn't catch that the lower passenger side of the radiator is bent in, along with the condenser. From the looks of it, the previous owner hit something, and never replaced the radiator and condenser. I've known about it for a while now, ever since I changed the grille emblem to a black one. Luckily, there's no leaks and my AC works great. I plan on replacing the radiator and condenser and possibly the fan assembly, if it's damaged when I have my oil pump gears done at some point, or sooner if it becomes a problem.
Anyway, while I had the bumper off, I noticed I'm missing several pieces of the air deflectors for the radiator, and hopefully seeing a picture of a Performance Pack car without a front bumper, I can try and figure out what components I'm missing. I didn't think to take any pictures when I had my bumper off, but just looking at it, it didn't look right.
Here's a couple of pictures of the damage that was done by one of the previous owners of my car. Hopefully someone has a picture, or can dig one up.
Jpump
Jpump
Arizona
Jeremy
DougS550
Fishers, Indiana
Doug
Drill Holes in a few places on both pieces and Zip Tie.
Jpump
Jpump
Arizona
Jeremy
I want it fixed correctly, so that's not an option unfortunately.
DougS550
Fishers, Indiana
Doug
If their are no holes then your going to have to drill them. That panel uses push in lock fasteners. You can make a bracket, use aluminum plastic rivets nuts and use M6x1.0 bolts.
Jpump
Jpump
Arizona
Jeremy
There's a bracket and a bolt listed, but I can't be sure if it's part of that deflector, or part of the shutter system.
DougS550
Fishers, Indiana
Doug
I would go to the dealers and ask the parts guy, they will know.
Jpump
Jpump
Arizona
Jeremy
I will at some point. I'm just gathering parts to replace all the missing or damaged parts my car came with. Thanks for the help.
DougS550
Fishers, Indiana
Doug
It sucks having to piece parts together a previous owner broke or Jerry Rigged. Good Luck finding the parts.
ORRadtech
Atlanta, Georgia
Perhaps going sooner rather than later would be advantageous. Their parts diagrams and lists are exhaustive. From all major components down to individual nuts, bolts and washers. Perhaps you could convince them to print out the pertinent diagrams so you can figure out exactly what you need.
DougS550
Fishers, Indiana
Doug
personal send me you MM Year and Vin. I will check. And if you have a picture of exactly what is missing or broke that would be great.
Jpump
Jpump
Arizona
Jeremy
I can get some pictures Sunday. I'll pull the belly pan and radiator cover off. Should be able to see everything that way.
