Quick E85 question
Decible
Georgia
Sam
2023 Mach 1 HP
A station not to far from me (Pilot) started carrying E85. My car isn’t tuned for it yet but in the future I’m going to have a flex fuel tune. I only run 93 in my car but it’s approaching 3.00 a gallon here and E85 is 1.92. Is it okay if I run it without the tune? I realize minimal performance benefits will be realized until it’s tuned. Wanted to make sure the factory calibration will make the adjustments.
codereddew
2019 Mustang GT PP1
no you need at least a tune to run E85
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
Awww thought that might be the case. Wasn’t sure if the stock tune had fuel trims to run it safely without a tune like a flex fuel car.
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
It seems the safe limit on stock tune is E30
Thank you, I wanted to check before I went and filled up. Looks like a tune is in my near future 🤷🏼‍♂️
cactus_kid
Big Bend Country, TX
Michael
'21 GT (see sig)
The bigger question is, are you comfortable with toasting the power train portion of the factory warranty ? The PCM will date/milage stamp the change. Ford will find it, even if you were to change out the PCM like we used to do years ago.
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
That’s the decision I need to make 😂
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
Like others have said adding a few gallons of e85 won’t hurt. I add it to 87 octane in my ecoboost ranger. But unless you have a big supply of e85 on hand. The mixing will get tedious.
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
I believe you also need a Flex Fuel Sensor not just a Tune.
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
I thought so too and from what I’ve read I. The 15-17 yes but not on the 18+. The wideband o2’s do the work for you.
Matthewstorm
NC
Matthew
Really? So, on a 2021 Mustang all you need is a Tune?
Does this break warranty?
acemastr
Tampa, FL
Aaron
2019 Ford Mustang GT Premium
No need for a flex fuel sensor, I just slapped a tune from LUND on my 19 and fill up with E85.
15-17 do need bigger injectors I believe since there's no DI
Decible
Decible
Georgia
Sam
2023 Mach 1 HP
The 21’s would just need a tune. I’m hearing the power train warranty could possibly be voided do to the reflash of the PCM
Matthewstorm
NC
Matthew
But you voided your warranty?
