Question regarding SP763 springs
spaz mk will
Indianapolis, Indiana
Will
2018 GT
For a variety of reasons, I only just got these installed this weekend. Rear springs are a pain without removing the RLCA but we did it. Have yet to drive the car , get it aligned, or clock the bushings. That will happen next week, I finally found an alignment shop that understood my request rather than being confused by it.
Installed the following -
| BMR SP763 | FP Track shocks/struts | BMR CB005 | Eibach bump stops | BMR TCA048 | J&M rear shock mounts |
TheMegalodon
Alberta, Canada
Triple Yellow 2015 Mustang GT PP
Sounds like a fantastic setup! Hope it dials in nicely for you man.
Try for 0.5 degrees less camber in the rear than front. I have the same springs and with .10 total front toe in (0.5 per side) and 0.26 rear toe in, my camber is about -2 degrees all around. I may back the toe out a touch in the back to 0.20 total to see if I can reduce the rear camber a bit since I believe they’re linked. Front toe in is preference. I like the tighter turn in response and the car feels well sorted on the street. I tried to get as close as I could to Kelly’s recommendations from BMR; they’re posted in another thread.
https://www.mustangecoboost.net/threads/alignment-specs.18895/
