Gotcha.. thanks! Would these work well with my stock shocks and struts or would upgrading to some PP ones be better?Both of these have the same spring rates at 170 and 740 lb/in front and rear. The SP080 has a 1.2" front drop and the SP763 has a 0.88" front drop (on the GT). Both have the same rear springs and a drop of 0.5". Given that you have the V6, I would go with the SP080, as it will look very balanced with about a 1" front drop, because of the reduced weight on the front.
The V6 with the SP080 will look like this (EB and V6 have almost identical front axle weight):
V6
https://www.mustang6g.com/forums/attachment.php?attachmentid=134669&stc=1&d=1500772641
EB
https://www.mustang6g.com/forums/attachment.php?attachmentid=150840&stc=1&d=1513980586
https://www.mustang6g.com/forums/attachment.php?attachmentid=145057&stc=1&d=1508943450
They'll work alright. You'll enjoy it more with PP shocks and struts.Gotcha.. thanks! Would these work well with my stock shocks and struts or would upgrading to some PP ones be better?
On the GT I agree. For the V6/EB the reduction in weigh off the front is enough to go for the SP080, IMO.I am a fan of the minimal drop. It messes less with the geometry although apparently the front end is less sensitive to geometry change from lowering.
