Question on using jack stands
ANGST
Herndon VA
18 Cayman GTS, 15 Explorer Sport , 09 Honda Fit
Strange question , usually I do my work on a 2 post lift . I may not have access to that in the next 2 weeks, and my Quickjack is not here yet.
I have jacking rails and put my car up before on 4 jackstands. Jack the middle and put stands in front and back, then do other side.
I need to to my front brakes , can I just use 1 jackstand at a time to do the fronts ? Jack up on the rail and put the stand on the front jack point ?
FreePenguin
Ohio
Donald
17 mustang
Its what I do.
very rarely do I need to use 2 stands at once, did my whole suspension swap one tire at a time. just walking around jacking up wheels each one I get too. oh are you saying
one jack stand to lift entire front of car?
I wouldn't. just my opinion. i put a jack on both sides of front jacking areas.
EVEN if the jack is capable, I dont feel its sturdy with just one point of contact, it can slide, etc.. 2 is better, for your safety. imo. dont do one jack for entire front car in air.
traktrbeam
Kentucky
2019 Oxford GT Premium PP1
I have jacking rails also. Whenever I put the car on stands, I have a floor jack on either side just touching the rails and locked. Better to be safe then dead.
ANGST
ANGST
Herndon VA
Its what I do.
I was just doing one corner at a time. Jack it up , one stand on a corner , do the brake on that corner , lower , then do the other corner .
Elp_jc
None
What I do when working on just one corner, is remove the wheel, then lower the car until level (or as much as possible), to avoid twisting the chassis for too long. But if wheel is too close to the floor, obviously that's not possible, but at least lower it as much as you can. And when removing the tire, I only jack the car enough for a few millimeters of clearance under the tire, to avoid injuring my back, AND hitting the caliper with the wheel.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
I wouldn't worry about that too much, these cars are pretty rigid, I could still open both doors just fine with one corner raised on each side.
