Question, how do you set a pinion angle on irs?
BDMACH1
Ravenna, Ohio
Bob
2016 Mustang GT/CS
Hey Kelly [MENTION=9985]BMR Tech[/MENTION]
Weren't you putting something together for us to check what our angles are at, and what they should be at? Like a quick How-To?!?!?
Dominant1
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
You dont set the pinion angle on an irs set up its static. I fixed my pinion angle at my trans x member by adding spacers 1/4 inch at all 4 points ..you can also adjust it with aftermarket motor mounts..
melwff
Danbury,CT
2021 Mach 1 M2486
there is no chance you coincidentally lost a wheel weight?
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Too many issues to do this, and too much time with doing tech. People just simply do not understand driveline working angles for the most part.
I help people out quite a bit though.
On BluBallz, I am running the pinion 1.8 degrees "down" in relation to the engine angle.
My engine angle is at 3.8 degrees "down"
Me pinion flange is at 2.0 degrees "up"
I set it with a combination of shims under just about every mounting point, front and rear. (front K-Member, engine height, trans crossmember, rear IRS cradle)
:thumbsup:
BMR Tech
Tampa, FL
Dion
Here you can see the shims [MENTION=19179]BDMACH1[/MENTION]
BDMACH1
Ravenna, Ohio
Bob
2016 Mustang GT/CS
Just an FYI, my car ended up needing the cradle shimmed down to get the pinion angle within the desired spec. @BMR Tech was a huge help in me getting the car sorted out. 95% of vibration issues are all gone, I'm in the process now of making some cradle shims to get the pinion angle exactly where we want it..
