Dominant1
Reason why, I had my car lowered before I added my 1 piece aluminum ds. The stock shaft never vibrated at any speed even when after lowered. Fast forward to now after my n/a build my dynotech ds and i get vibration starting at 60mph and through 80mph its down right annoying now. It increases lifting off the gas at those speeds. It rattles the inrterior panels when I'm in that speed range. I have steeda irs chassis braces that bolted up with no issue. So im assuming the cradle is aligned. I think the vibration is because with this dynotech ds you must have the correct pinion angle. The dynotech does not have the benefit from the stock ds's cv joint style. Please chime in
