Question About Exposed Electrical Connection on Engine (V6)
m2016v6
AB
2016 V6 Base Convertible
I have a 2016 V6 convertible. This is the engine:
There appears to be an "exposed" electronic connection:
Is there supposed to be something covering that up? Like some sort of cable wrap or something? I've been driving around like this for quite a while, so it doesn't appear to make a difference, but now I'm curious.
I am also embarrassed to admit I don't know what this thing is.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
That appears to be a pressure sensor for the intake manifold, measuring pressure / vacuum. The connectors have seals on them that keep the water out (within reason - don’t put a pressure washer right up on it). If you look around more, you will see many similar connectors that look the same way. I see several in your image, in fact. I do not see a problem in this image.
m2016v6
AB
Thanks, Mike. I bought this used in March, and there were so many missing little pieces, I figured there might be a missing cover here.
momalle1
Massachusetts
2017 Mustang GT Premium
I'd wrap some electrical tape around it and call it a day.
ORRadtech
Atlanta, Georgia
No, no, no, no.
At least not the plastic stuff.
If you just can't stand it, get the dedicated harness tape. It has a soft cloth like covering and adhesive that sticks to the wrapped harness very well without turning into a sticky, gloopy mess.
But, as Mike said, that is perfectly normal and needs nothing more done.
Crew4991
Crew
Those exposed connectors are fine. Nothing to worry about.
The V8 and the ecoboost have plastic covers on them for show, if the covers are removed then the connectors on those engines are also exposed. Doesn't make a difference.
momalle1
Massachusetts
No, no, no, no.
I meant over the exposed area, not the wiring.
ORRadtech
Atlanta, Georgia
Same answer, don't use the plastic electrical tape. Once that stuff gets hot it turns into a sticky mess. Cover the connector with it and you have a good chance to gum up the connector and attract dirt making it a bear to get off. Harness tape is a better option in nearly every underhood situation.
m2016v6
AB
Thanks for all the replies, I appreciate the effort. I think I will do nothing!
Skye
≈39N
"Skye" Mach1 N2144
momalle1
Massachusetts
That's not true, but whatever, I'd cover the exposed area.
ORRadtech
Atlanta, Georgia
What part do you find untrue?
The sticky mess part?
The attracting dirt part?
That harness tape is better for under the hood part?
Cover yours if you want, people do useless stuff all the time.
momalle1
Massachusetts
Lol, how did I know you'd be back?
ORRadtech
Atlanta, Georgia
Probably the same reason I knew you would respond with no constructive content.
