Pulley down on a P1X
SolarFlare
S. Fla
2015 CO GT
Gen2 stage2 redline is 7500, crank pulley is 6.75 inches pc pulley 4.88 ..calculator says 42,533 rpm at redline..
Gen 2 stage 2 is an 8” crank pulley. You’re slightly over 50k
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
oh i had the crank pulley diameter wrong, ok thanks. I just did calc with a 4.38 pulley & thats just over 56,000 rpm..I wonder what king of power my d1x would make on e-85 with a 4:38 pulley probably over 900-950 but I’m guessing..
SheepDog
Colorado
Dax
OP, your gonna want a fuel system before going to E. I wouldn't trust that DW400 to supply the volume you will need, especially if you pulley down. Definitely get yourself a Griptec pulley. Im running the 3.25", no slip at all.
Keo_S550
Keo_S550
Missouri
Daniel
2017 S550 GT Premium Ignot Silver
Yeah I have a Lethal kit on the way.
ahl395
Allan
For those interested I managed to squeeze 21psi out of a P1X. Stage 2 3.85" pulley, revved to about 8k. 69k blower RPM. Stock headers with cat deletes.
Keo_S550
Keo_S550
Missouri
Daniel
Built engine I’d assume. What did she run?
ahl395
Allan
Built engine, only made 829whp but I have some other issues to work out and then I think it will make more.
Keo_S550
Keo_S550
Missouri
Daniel
Definitely should make more than that. Good luck finding those issues. I just want to get to the 800s then I’m done. I’m not gonna build the engine unless I really have to which means unless it blows up.
