Pulley down on a P1X
Keo_S550
Missouri
Daniel
2017 S550 GT Premium Ignot Silver
Currently running a P1X on a HO kit with Stage 2 Intercooler and Big Red Race Valve. Pulley size that I’m running right now is a 3.75 and I’m seeing 8lbs. I understand boost is mainly a number and 1/8 to 1/4 times count but I’m wondering what size Pulley is people running with similiar setups? I’m gonna stay on 93 for awhile till I make the jump to e85. Lund has me limited to 7k rpms due to having 47lb injectors but I just got a great deal on ID1050x injectors so I’m sure that won’t be an issue anymore and I’ll be able to rev higher. Rough HP numbers? Will head to the dyno soon once I switch out injectors.
Other Mods:
Stock Headers
No Cats
DW400 FP
Vector
Ohio
S550 A6
Not a fan of 93 on these cars with boost, you are probably good where your at with 93. To many engines get taken out on 93. Maybe not here but I have seen plenty on Facebook groups.
If you can get the revs bumped to 7800/8000 it's like going to make 10bs.
It will for sure feel better revving higher.
I would not change the pulley without E85.
Keo_S550
Keo_S550
Missouri
Daniel
Yeah I’ve seen my fair share of engines blown also. Just trying to get a consensus on what other people are running as far as pulley size on 93. We will see on how these new injectors will run and how high it’ll let me rev on this setup without going too lean.
Once you get injectors, 680-700whp is easily done on pump 93. I've been 9.80 at 141 on 93.
Those are the numbers I’m trying to hit. I’d be happy with high 600s. Or mid 10s on the track. It’s a manual so the track learning curve with a high hp car is rather steep. But those are my goals for it being a daily and all!
Keo_S550
Keo_S550
Missouri
Daniel
*Update* After installing the 1050x injectors a few months ago and Lund releasing the rpm hold from 7k to 8k I’m seeing 12 psi at 7800-8k on 3.75 pulley. Just purchased Lethals level 1 kit and going to make the venture into E. Thinking about pulleying down to maybe a 3.375 or 3.5. I don’t have headers so maybe hold off on the 3.375 because that would put me close to 16psi and I hear that’s the max anyone would go on a stock motor and trans. Is that a fair assessment or send it? This is my daily driver and I rarely get into boost on the weekdays or on the weekends with the boys.
Jay-rod427
Kansas
2016 GT C/S
16 lbs on E85 is acceptable on a limited basis. Kinda the upper limit on getting it to last, but should make 750 or so. Those tiny pulleys on the 6 rib may experience some slip tho.
Keo_S550
Keo_S550
Missouri
Daniel
Tracking. When I do pulley down I’ll be going with a griptec pulley to help prevent slip.
Jay-rod427
Kansas
2016 GT C/S
Honestly if I were you I'd stay on the 3.75". Unless your squeezing out the last little bit at the strip it's minimal gain, and much easier on the engine. Would still be hella fun on the street. Going E85 will be a very noticable difference at the same boost.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
You can spin the p1x up to 65,000 rpm so calculate your crank pulley diameter of sc pulley diameter to and see what your spinning it at.
Choose belt
https://www.procharger.com/calculators
Dominant1
Dr Frankenstang
My current Max rpm on my Procharger set up is 42,553 rpm on the 4.88 pulley. Max Rpm on a D1x is 62,000. So I really haven’t even scratched the upper end of this blower’s capability.. I will turn it up when my transmission gets done. I Will talk to my tuner when i drop my car off for the trans build Next week..
Keo_S550
Keo_S550
Missouri
Daniel
Choose belt
I’ve used the calculators. Currently shifting at around 7500-7800 I’m spinning it to about 59k. Now if I drop down to a 3.50 id be at 62k or a 3.375 would be 64k at 7800rpms. Peak boost is around 7100 rpms or alittle less.
SolarFlare
S. Fla
2015 CO GT
Don’t you have a gen 2 with a stage 2 system? Are you limiting the car right now to 6500rpm or something? If not then you’re more like 50xxx
Dominant1
Dr Frankenstang
Gen2 stage2 redline is 7500, crank pulley is 6.75 inches pc pulley 4.88 ..calculator says 42,533 rpm at redline..
