ThirtyThreePointThree
- Nov 19, 2014
- Austin, TX
- '15 White EcoBoost AT
I actually do have plans for a spare tire eventually. The 3/4" MDF is temporary to have a good mounting base because I was tired of hearing stuff slide around when I would take a corner at fun speed ;)Awesome, make sure to document everything in pics as it's supremely helpful to those of us who haven't hacked a modern system before. I take it you have no plans for a spare tire? When I installed my bottom layer from plywood, I made a hinged door in order to pull, replace the spare tire.
As an aside, are you running new wire from the amps all the way to the 3-way speakers, or just cutting in at the amp and using the existing door wiring? It looks supremely difficult to get wire through the door-canal thingies.
I'm planning on building a box with shelves to place up against the back of my seats to house all of my amps/DSP, and this box will be all one unit with the sub enclosed as well. It should be far enough back that I should still have spare tire access, we'll see how that goes though...Like the hinge idea btw.
For the wiring question, I was lazy and just spliced into the existing wiring infrastructure(there will be pics of this mess under the driver's side kick panel in a few days when I run the tweeter channel lines). I haven't spent much time looking at how painful the routing through the door hoses would be...I'm thinking super painful as newer cars only have more wires. With the stock 18AWG wires, I'm not too worried about signal to the mids, but I am worried about the door woofer. I'm eventually gonna throw somewhere around 70W RMS at it...
