NO1CARES
- Dec 29, 2017
- FALLING WATERS WV
- 17 GTPP 5.2 TH400
Yes sirAre those the GT500 cam covers ?
I was able to feel it as soon as i was backing the car out of the driveway for the first drive so i did anticipate it from there on out. Everything is fine when you hit the peddle for the first 3 times but it uses all its reserve and can't build the vacuum back fast enough. Something i didn't take into consideration when the engine was degreed. But i'll get it straight. i really refuse to go manual brakes so if anything, i'll just put a 6.0 external electric vacuum pump specifically for the power assist and go from there.That sounds scary. No brakes.
This is good to know. sadly, everything is now on delay.On my 66 I had power brakes with an electric pump in the trunk, worked great. I had power brakes with the engine off.
Yea, the stock motor just had a hurt head gasket. The built short block just had a piston rattle and was blamed on timing. So nothing was covered at all.Jesus Christ dude. Sorry to hear.
remind me, when you pulled your stock motor, was it running? Did Holbrook cover the first motor that got hurt fully?
these are custom blower cams by comp cams/HolbrookDamn man sorry to hear about the engine issues. Sounded killer on the idle vid though!!! What cams? This car should rip once ironed out.
really hope they don’t try to hit you with more shenanigans this time.Yea, the stock motor just had a hurt head gasket. The built short block just had a piston rattle and was blamed on timing. So nothing was covered at all.
honestly, I really don’t see how they even could. I paid for everything to be done and done right. I can show him every data log of the car running because I’ve been working to get the idle and drivability corrected. But we will see. Anything is possible.really hope they don’t try to hit you with more shenanigans this time.
